So yesterday afternoon i decided to tackle my steering rack bushings, my steering was really kind of sloppy thanks to this site there were very clear instructions on how to change out the bushings. I was under the truck with the bolts all undone and the rack moved back enough to get the old bushings out. I was using an exacto knife to try and cut the drivers side rubber to make it easier to pull out the bushing when it slipped and put a .5" cut in the drivers side steering boot! Damn Damn Damn!! I few drops of oil came out of the boot as well....Hmmmm is this normal? I'm thinking maybe the rack seal might be leaking a bit...My plan is to try and patch the boot maybe with some kind of sealant I don't really want to pull the tie rod end and replace the boot if I don't have to at least not right now. I'll probably try and run some Lucas Power steering sealant as well to try and swell the seals and maybe buy myself some time. Any input on how to seal the boot again?
As a side note the big washer that everyone says can be pulled off from the bushing between the rack and crossmember was attached to the bushing..the bushing eventually came out whole with the washer attached. The rest of the job was uneventful just ended up taking 4 hours start to finish with taking the tires off. Steering is now nice and tight!
Checked my ball joints while I had everything apart and they're solid!! Woo Hoo I was dreading the thought of having to replace those too.
