Ace's 1998 4Runner Build Thread
Yesterday I noticed the fan clutch was loud for too long so I ordered a replacement.
Tim covers diagnosis of a bad clutch & replacement here -
<iframe width="740" height="416" src="https://www.youtube.com/embed/WzhlACxqeqQ?t=170 title="Fan Clutch Replacement" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" allowfullscreen></iframe>
Since my 1998 has no imobilizer/chip key I bought this Viper 3505V 2 way alarm at Amazon-
Look up ways of doing a secondary kill switch that interrupts power to the fuel pump. Hidden and separate from the alarm. Won't stop cat thieves or a tow truck... but then you should be pretty safe.
-Charlie
Removed and replaced the fan clutch, used this one -
https://www.amazon.com/dp/B0819TWFQT?psc=1&ref=ppx_yo2ov_dt_b_product_details
Also replaced the rear liftgate struts with these -
https://www.amazon.com/dp/B00W8QBA30?psc=1&ref=ppx_yo2ov_dt_b_product_details
Amazon.com
Amazon.com
Happy to see this kind of maintenance getting done. I personally have Strongarm struts on the rear hatch of my 4Runner as well as on the hood of my Honda Accord. Great results. Thanks to @%1;for promoting these in the past, that’s why I went with them.
For the fan clutch I’m surprised you didn’t go with the saison unit. It’s under $100 and is OEM, but I hope you have good results with this one nevertheless.
-Charlie
Earlier in this thread I posted that I installed a transmission skid plate / CAT shield, so the CAT protection has been addressed. Tow trucks and wheel thieves aren't much of a concern.
I did order a Directed Electronics 506T I.T. Audio Sensor to add to the Viper alarm to detect window breakage. Inexpensive and easy to add to the system, seems like a no brainer to counter smash & grab thieves.
Got a few things done today - the rear diff breather mod and I painted the rear drums.
Tim covers how he did the breather mod here -
I bought the steel nipple, vent valve and the hose all on Amazon. The two "Toyota" parts I received were in plain plastic instead of the normal Toyota packaging so I kept the steel nipple but returned the valve to Amazon & ordered one from Toyota. The one from Toyota did arrive in normal packaging so I'm guessing the Amazon parts were knock offs.
Here is the 5/16 tubing I bought, came with clamps -
Amazon.com
I removed the rear differential vent after I wire brushed the area of dirt, then installed the nipple with some teflon tape-
Then it was a matter of routing the hose up to the gas cap area and securing it with zip ties.
I removed the two bottom panel fasteners for the fuel filler neck cover but like Tim I had to break the upper pair. No big deal, I had spares from another job-
Amazon.com
I made my hole in the fuel filler rubber surround with a bolt that I heated up with a propane torch. This created a nice, round hole for the vent to go into.
Then I put the new vent valve through the hole and connected the tubing after cutting it to length. Lastly I installed the clamp and installed the fuel filler tube cover. Here is the routed vent line -
Since I had to remove the rear wheel to access the fuel filler tube area I decided to paint the rear drums.
They were't too rusty but I cleaned them up with wire brushes & such -
Then some Rustolem rusty metal primer and satin black -
One more thing I did today - replace the faded warning decal on the driver's door panel -
Before
cleaned with denatured alcohol
after -
I prreviously installed a Talons Garage Transmission /Cat skidplate to protect both items. This is a really nice skidplate that has an additional wing on the passenger side to protect the catalytic converter from sawzall attacks.
Here's what it looks like on my 1998 SR5 -
Being that cat thieves are going to be in a hurry I wanted to install an additional shield or skidplate to stop them from cutting off the back of the cat before realizing they can't get to the front.
I could buy a transfer case shield from Talons but thought I'd just make a shield myself out of stuff I had on hand. The shield will only make the thief pause so that they can move on to easier pickings.
Looking around I found a piece of galvanized sheet steel used in HVAC, left over from a previous project-
tuṣṭāva
