so the steps you mentioned above will make it work? or are there more detailed instructions to follow?
Yes, you can google "programming Homelink Toyota" Or there are threads about it on here.
I am the 3rd owner but it is a very clean stock Runner with nothing modified So I am guessing it is factory but could be wrong.
Good to know. Thanks.it is a factory option on the 2001-2002 Limited. and yes, it's on the LH sunvisor.
<img id="ums_img_tooltip" class="UMSRatingIcon">
If you are going to do this, why not spend a few more dollars and get one of the rear view mirrors with it built in? Makes more sense then hacking up the interior and when you are done, it will look like it belongs there from the factory.
Hum, I bet buying the pre-installed visor from Toyota would cost your firstborn.
After I learned of its existence, I called the dealer, the part has been discontinued and none avail in the depot.
Few more dollars?
#1. Toyota mirror with Homelink $225. And no direct fit replacement
#2. Drivers side sun visor with Homelink $176. Discontinued.
#3. Adding Homelink on your own $18 and an hours work.
In a nut shell.
Yes, a few dollars more.
Homelink mirrors can be found on ebay for $50. It doesn't have to to be one from a Toyota and getting it to fit would not be hard but yours is not "direct fit" either.
In a nut shell.
A random Homelink mirror off of eBay will not fit the 3rd gen 4runners, the base has to be a dual screw base, not a stick on base.
Put your money where your mouth is, make one fit and look like it belongs and post your results...you can't, you won't, and that's the reason we use the home link we all have used...
I'm am sorry we are all doing it the wrong way for you, please feel free you hack up your dome light and mirror to find a better way and prove us all to be morans.
Actually, my 4runner does have a stick on base.
Even though yours does not, you wouldn't have hack anything up to add a stick on style.
As far as putting my money where my mouth is, I see no need to go through all this effort for a garage door opener. I was simply making a suggestion there is no reason for you to get all uptight or defensive. It isn't like I told you that yours looks like sh!t.
3rd gen 4runners rear view mirror bolts to the dome light bracket and then the dome light cover clips over it to cover up the exposed frame (at least the two I have owned do 1998-2000)So if you just pull the rear view mirror off and stick one to your windshield you would have a big ugly hole in your dome light housing and wires running down the windshield a couple inches to the rear view mirror.
