Adjusting/aiming fog lights after lift?
Lifeline
OK I had a quick question. I have seen the posts and threads about aiming headlights correctly after lifting the 4Runner. Has anyone ever aimed or adjusted their fog lights after a lift?
I did the Eibach Pro lift on my 4Runner. Which is 2 3/4 in the front. I have the Baja squadron sport fog lights, and they just don’t seem as bright now that the truck is raised. I can definitely tell a difference with the headlights, and will be adjusting those here shortly. Is there a way to end the fog lights down a little bit, to compensate for the lift?
I know when I swapped bumpers, I saw an adjustment knob on the fogs. But I didn’t adjust it. Not sure if it’s up/down or left/right. Here a pic. Keep in mind the fog is sitting in a limited bumper which I eventually swapped to a TRD bumper.
You can try loosening the brackets a little and see if there's enough play to aim them down and tightening them.
This adjustment dial is on an OEM fog light assembly. It does not exists on aftermarket ones such as BD.
brendaglores
