After AFE Sway-Away, which rear springs give the least amount of lift?
Rysandro
I have a 3rd Row Limited, The AWD alone adds a couple hundred lbs, and the 3rd row a little more. Looks like some 3rd row Limited's are actually getting the 1.5" advertised from SwayAways. But im looking for a tiny bit more lift than that.
A 4x2 SR5 weighs 500 lbs less than a 4x4 Limited. So i do believe id get around 1.5" rear lift with sway aways.
After the Sway Aways, which Springs would give the least amount of lift? Icon 52700? Superflex (NON HD)? Wheelers T12?
Wait...you want more than 1.5" of lift? SAW will probably get you the least amount of lift (advertised as 1.5" but close to 2" without 3rd row). Almost everyone else's springs are around 2" of lift (OME medium, Icon standard, Toytec RCC2.0, etc.).
I have SAW and with 3rd row I got 1.5" after settling. To answer your question, ome 895e would probably give the least amount of lift next to SAW. From I've read, they provided 1.5-2" of lift. I'm sure someone who actually has ome 898e will chime in.
I started with SAW, it sound like OME or super flex might work, I would not factor the full time 4wd into the equation, also check here:
http://www.toyota-4runner.org/5th-g...-4runner-suspension-options-lots-choices.html
Ome 895e chiming in, you are spot on about 2.5 initially and 2 settled. They ride very nice with or without the 200 or so pounds of gear in the back
Sent from my SM-G920V using Tapatalk
patnewton
