After Doing Some In-Dash Work, Fans Don't Blow (Heater and AC)
Koko4
Yesterday I did the Tacoma Whip Antenna mod, which required me to pull apart the dash pretty extensively. I also lengthened the rear window switch so it is now located next to the RR E-Locker button. I had the driver's side dash panel off, the center console all taken apart, and the glovebox removed / small black plastic panel above the glovebox removed. All of this is to give you an idea of the areas I was working in.
Today, I have NO air blowing from my vents. When I push the A/C button, it does light up, and I can hear the change in engine speed so I'm assuming the A/C compressor is still kicking on. It's as if the blower stopped working altogether. I took everything back apart to look around and see if I could have knocked some connector loose by accident...no luck. I checked the 10A fuse under the hood (A/C fuse) and it is fine.
Any idea of where I should look next? I'm supposed to take this 4Runner out of town Sunday morning and can't be without the fans working.. =/
IMG_20140327_115900_zpse55c698a.jpg~original
pax at 4
