HiluxSmurf
Unfortunately, these new lights are not OEM quality. I had to trim the driverside turn signal socket because the pattern on the housing is backwards. Also, on both headlight housings, they left out part of the casting that securely locks in the hi-beam bulb behind the socket. I added a short screw to help hold the bulb in place.
I had the same experience as well. Prior to installation, I ran a bead of clear RTV silicone around the seals, trimmed the turn signal socket, but didn't mess with the loose high beam sockets. I've been running around Florida in high humidity and rain for over a month now with no sign of moisture inside the housings as of yet...
