Aftermarket CAT - which do you recommend?
The part you are talking about is probably more than you need. If you just need the cat, and not the O2 sensor mounts, Amazon has a universal fit Magnaflow for $100...double check, but I think this one will fit. It cam just be welded in place along the exhaust.
Magna Flow 94300 Series Universal Catalytic Converters (High-Flow, Oval) Cat 2 1/2 Inch IN/OUT Cat 2 1/2 Inch IN/OUT (NON CARB COMPLIANT):Amazon:Automotive
That might not be the correct one. According to the Magnaflow website, it would be either the 99006HM, or the 51006.
Also, both of those say that they qualify for 15% off in the cart.
[MENTION=25434]BamaDrewski[/MENTION]:
Is yours a federal or a Cali?
Do you have to do smog tests?
Just do this, and don't worry about the cat at all.
If you don't have smog tests that is.....
http://www.toyota-4runner.org/3rd-gen-t4rs/175242-how-make-your-own-rear-o2-simulator-$5.html
My CAT is a 49 state version. Also, we do not have smog testing/inspection as a requirement in Alabama. I am sure your rear 02 simulator works great but I am reluctant to try it.
