Air Compressor 12 volt, 100% duty cycle
ARB twin. 100% duty cycle. Built and tested in Australia.
Several of us on here - including myself - are using them. Mine has been awesome, it has fantastic air flow and has been perfectly reliable.
i run dual viair 480c compressors in my volvo. i run a 380c in my 4runner with my train horns and 1 gallon airtank under the hood
Your air compressor is equipped with an AUTOMATIC THERMAL OVERLOAD PROTECTOR.
This feature is designed to protect the air compressor from over-heating and causing permanent
damage to your air compressor. The thermal overload protector will automatically cut off power
to air compressor should internal operating temperature of the air compressor rise above safe
levels during excessive use.
I read the above on the viair instructions. Have any of you had you unit shut off due to approach of thermal overload?
China havin, import lovin' mo fo here...
Been using the Puma 12v for trips and trail runs, so far to date it's done a great job. I also have used it at a frinds cabin running a nail gun (I'm lazy) and it's been a big hit blowing up air stuff as well. Great price point, and to hook it up all I did was cut off a pair of heavy jumper cables and wired them on.
Puma 12 Volt 1 5 Gallon Oil Less Air Compressor Free Shipping | eBay
