Air compressor choices
I have had the viair 400p in the bag for about 4 years now and it has always worked great. I recently installed it under the hood to save some cargo area. Really easy to install.
For the VIAIR 400P-AUTO
31″ X 10.5″ FILL RATE
0 to 30 PSI 3 min. 00 sec. (± 10 sec.)
15 to 30 PSI 1 min. 35 sec. (± 05 sec.)
33″ X 12.5″ FILL RATE
0 to 30 PSI 4 min. 20 sec. (± 10 sec.)
15 to 30 PSI 2 min. 05 sec. (± 05 sec.)
35″ X 12.5″ FILL RATE
0 to 30 PSI 5 min. 20 sec. (± 15 sec.)
15 to 30 PSI 2 min. 45 sec. (± 05 sec.)
- from 400P-Automatic Portable Compressor | VIAIR
I have ARB Twin after having and returning the 450P Auto. The Viair worked but it was slow. I was between the 400P and the 450 and decided on the 450 due to 100% duty.
Ended up with the ARB after finding used (never used) so it worked out for me. I ended up mounting with a 1 gallon tank using the Bandi mount. The one thing that really sold me on the ARB is that it's always in the truck, not just if i put it in there.
Yeah, it's expensive but its the cry once, buy once mentality.
My Porter Cable Compressor.
Smittybilt 5.5 cfm
I upgraded to viair 450p then saw my buddy used smittybilt and was way faster, So I switched to smittybilt. only two things wrong with Smittybilt and they are easy fixes for $20
added air pressure switch and I/M air chuck and it's better than most portable air pumps
VIAIR 300P in a bag. Does 18psi to 38psi on 265/70/17s in decent time. ARB single under the hood is primarily for the locker, but is also setup to be a backup just in case. The VIAIR shows no signs of stopping though. Automatic shutoff would be nice, but not necessary.
In my case, all i wanted to upgrade is use a longer wire instead of longer air hose. It does not make sense to use a longer hose if the switch is at the compressor. I only inflate one tire at a time.
Not sure what you guys thought of as the best choice in 2019 but right now I have a very nice Dewalt which I bought for a low price!I was just looking for that as with Toyota models this can become a challenge to find, even online. There are some specific requirements for my Cayenne as I need perfect inflation levels in order to not have performance issues. I like to hit circuit races once in a while with it for fun, so for me kylesgarage.com was a great encounter in order to find an affordable air compressor that matches my car's specification. Moreover, it includes various models that are under 200$ which is a bargain for a quality piece which you have for other uses too.
The smittybuilt is at the top of my list. But no one as mentioned the Desert Armor Beast yet. I want to get my hands on one and see if it will fit under the hood.
I have the ARB twin portable setup that comes in a plastic case with a tank. Very fast, but takes up too much cargo space so I took it apart and planned to install it under the hood on my 5th gen. NOPE. Does not work with the M.O.R.E. bracket because the compressor is a slightly different design than the one made for mounting. Maybe other brackets will work but I doubt it.
Laredotx
