Air intake chaimber removal
4running1990
I have a 3.0 and i am trying to replace the fuel injectors but i cant get to them because the air intake chamber is in the way i took off 6 bolts and 2 nuts that appeared to be holding it on but it stilll does'nt want to come off. Are their any other "hidden" bolts or nuts?
Are you talking about the whole air cleaner assembly or just the hose going to the throttle body?
When I changed my spark plugs and wires, I just loosened the two clamps holding the hose onto the throttle body and air cleaner box and worked it out.
Sounds like you have it. I seem to remember 6 bolts and 2 nuts. Remeber there is a gasket that is probably stuck, and will need replacement for re-install.
Zett
