snow&surf
After driving about 1k miles with my setup I decided to measure the distance from the center of my wheel hub to the fender as many of you who have already lifted done. Unforunately I did not measure this distance prior to installing the lift so I don't know exactly how much lift I got :crybaby:.
Anyway, all measurements are 24" except for the left rear which is 23.5". I did get an alignment done immediately after the lift was installed. Now, I have been feeling a slight pull to the left when driving and was wondering if this is due to the fact that my left rear is 0.5" shorter than the rest of the truck lift. If the difference in the measurements isn't causing this because camber/caster/toe adjustments can be made then should I get the truck realigned or have the shop make everything even? I also wanted to know your thoughts on if this would create any problems with the suspension or the wear on any of the tires because of the one off measurement. Any help would be appreciated.
