All y'all LED fog light guys, I have a question about install
skt4271
Ok dudes, I installed my fogs, that pass side was a pita for sure. Anyway, everything works but I tried my best to clean up there hanging wires. Anything else y'all do that I'm missing. The DS I got zip tied to a hole in the frame. The PS is kinda just dangling and zipped to a white looking box.
LED are hella bright, the DS didn't make a click sound like the PS, should I go and try to press them again to hear the click?
Xenon depot if that matters-
Well I initially put a loop in mine and then secured it like you did. Then my ocd got the better of me and I clipped the harness to the led and put the correct toyota plug on it. No more excess wire.
Sent from my SM-G920V using Tapatalk
I used a baja designs kit that came with an adapter. Not exactly the same as yours. But sounds like the same thing I came across
So you cut the hid plug and hard wired it?
Yeah my lights had a baja designs style plug so it had a 6 inch adapter you had to plug in to make it a Toyota plug. I got rid of the adapter cut off the "hid" baja designs plug and put a Toyota style plug on instead. Now the wire is all factory length. No more zip ties.
Just took the right tool, I have crimps so that you can make your own connectors. Took 10 minutes
patnewton
