James_T
After my stock sub had blown out, and my desire to get a new dedicated 4 channel amp to power all speakers, I had the bright idea to mount it to the stock JBL amp location. Originally, my plan was to get it just sitting below the driver's seat, but I decided for a more permanent route. I don't have a write up done or anything, but I just wanted to show a pic for possible inspiration for others.
Once I put everything back together, it looks absolutely stock, save for the blue/red light on top of the amp showing through the speaker grille. The wires are run along the door sills, and across where the rear seats are mounted, and under the carpet. The only visible trace of amplifier wire is in the engine bay.
The mounting bracket was made by spray-painting a "shadow" of the mounting bolt locations of the stock sub box, so I could kinda "guess" the location. Each pillar for the bolts has a 2~" inch bolt through the center, capped off with a nut for added strength. The mount is rock solid, and will not even budge with my full force against it. Amp is bolted down as well, and all with washers, of course.
If anyone is curious how the speakers are wired, Metra sells a kit called the Metra Turbowires, which connects to the stock harness (pictured above, the big white connector) and terminates in 10 feet long wires which are color coordinated to the stock speakers. I just cut them to length, and wired in everything.
Metra TurboWires 70-8117 Wiring Harness is where I got the harness.
Word of warning, I had to wire resistors inline for the front tweeter, since the way you have to wire it for center speaker sound is to bridge the LF speaker positive to the LR speaker negative, which sends twice the RMS to the single tweeter. I blew it up real fast, haha.
To replace my stock sub, I also had to add:
The screw down ties are to prevent the subs from moving around. Works perfectly.
