Another Battery Problem Question?
Actually been planning on getting one of these for a while now, can you leave it on the car for a long period of time without any problems?
Yes, these regulators are designed to put the battery through different charging states. You can leave them on permanently. I found out about them through my work. We put these on all our generators.
If the battery has been drained flat several times, like 5 or 6 times, it's basically destroyed anyway. I see a new battery in your future, no matter what else needs fixing.
Yeah forgot i had a battery tender from my motorcycle, should and could have used that to retain the charge :der:
I plan on replacing my costco battery anyways there warranty is very good thats why i went with them LOL
*UPDATE* So i checked out the battery terminals, and sure enough negative clamp was pretty loose!
Took out the battery Cleaned the terminals with wire brush and charged it, hasn't happened since, and i used it quite frequently this weekend. Thanks guy for all the help!
alexaturner
