5100s F&R. Front set to 2.5", rear 1.75" Dobinsons Rear Coils. Maybe a 1/2 inch rake... this is on 275s but I am going to 285s next week.
they are 1.85-2 I have 3rd row and got just under 2" it is perfect IMOHey, why 1.75 inch rear coils and not a 2? I plan on going with 6112s up front and 5100's I'm the rear. I've looked at the dobinson 1.75 you recommended to me in another thread but I was just curious why not 2? Would that have helped with the .5 of rake you mentioned or only made it worse?
well you dont need UCAs in the rear so lift away lol.... depende on what you are gonna do up front. I have 5100s set to 2.5" and OEM UCAs with good alignmentWould I be better off going with 2 if I don't have a third row? Any recommendations? I'm trying to keep the lift to 2 inches so I don't need UCAS and can fit 275s with 0 rub
Hahaha. This is why I asked my initial question. Until it was explained to me in the above posts - I couldn't wrap my mind around how much lift my truck would have with a 2" coil and a 5100 strut set to the various different height adjustments. I now see that regardless of where the 5100 is set, a 2" lift coil will provide 2" of lift to the truck & the 5100 setting will simply affect the preload or compression based on how much up or down travel the strut has.
Long story short I was thinking that none of the strut settings would change the 2" lift.
Now I have decided to proceed with the 883 OME front coils (which claim a 2" lift) & I will set my 5100's to the neutral 0" lift setting. This paired with my rear 895 OME coils and 5100's should give me a front and rear 2" lift all around.
You actually need to add the setting height to the total lift with the 2" spacers.
i.e. .85" setting on the strut would be 2.85" overall lift. 1.75" setting would be 3.75" overall lift.
Now that being said. People who are installing their lift and measuring before they have their rig aligned properly isn't getting the true height of the lift.
Because the when you lift the vehicle the tires tilt in a arch and causes artificial initial lift. It's only after you have the CAMBER set properly that you will see the true height gained by the lift. (remember using the exact same tires and rims as before the lift)
Make sure any measurements you do for lift? Is done on a properly aligned vehicle. (CAMBER and to a small degree CASTER can change ride height)
IFS Isn't as straight forward as straight front axle.
And you want the 884. The 883 is for the earlier gen 4runner. (03-09)
Look at the bottom of this list.
https://toyteclifts.3dcartstores.com/Front-OME-Lift-Coils_p_211.html
Actually I'm looking at wheelersoffroad & they are stating that the 2883 front coils set will lift 2" on a stock 4wd 2010+ runner without any extra weight...
Actually I'm looking at wheelersoffroad & they are stating that the 2883 front coils set will lift 2" on a stock 4wd 2010+ runner without any extra weight...[/IMG]
Old Man Emu coils
Select coils from options- All coils are sold in pairs
-883 --- Front Coil Springs: Used alone as leveling coils (approx. 1 1/2") for 07-09 FJ Cruiser & 03-09 4-Runner.
The coils below are for 07+ FJ Cruiser & 03+ 4-Runner.
---884--- 2" lift standard coils - add top plate spacers for full 3" lift
---885--- Medium 2" lift coils for 110 lbs additional front weight
---886--- HD 230+ lbs- 03-09 4Runner Only
---887--- HD 230+ lbs - 2010+ 4Runner Only
(Choose from options above)
We recommend Old Man Emu 90000 shocks (sold separately) to be used with OME coils. 885, 886, and 887 coils will NOT work on stock shocks
A lot of ppl here have 884 set at zero on Biltsteins and got about 2" of lift. I have them but haven't installed them yet. Was inspired by [MENTION=125906]Shred_Head[/MENTION] build http://www.toyota-4runner.org/5th-g...2s-15-sr5-build-photo-thread.html#post2545501
Anyone have a pic of 1.75" front, 1" spacer in the back with oem size tires, 265/70/17? Planning on doing this but wont be going bigger on the tires for a while since I bought my ridge grpplers not too long ago.....
Does anyone know what is the largest tire you can use at this height setting without any other mods? I have the black trd 17" wheels.....
I'm currently running my 5100s up front at 1.75" with a 1" cornfed spacer in the rear. I want to increase my fronts to 2.5". What are most people running for the rear spacer at 2.5" up front? Cornfed makes a 1.5" and a 2". I wish they made a 1.75" as that would seem perfect and maintain the same rake I'm currently running.
OME 885/898 on 5100s set at 0 - no real extra weight yet......
No complaints about the ride at all.
I also didn't realize before dropping $40K on this thing that it rides as rough as my Jeep WJ does on the road... which defeats about 70% of the reason I bought the d*** thing... So, this makes me almost positive that preloading springs up front is simply a bad idea for the type of ride I'm after.
Thank you!!
