Antenna Block Off
cbielat
Senior Member
Seeing how I don't have satellite radio or even use my radio for that matter, this is the simple route I took to get rid of the antenna. Initially, there was a tiny space between the base of the antenna and the flat top of the plastic screw. With slight pressure and a bit of a tightening turn, it seated securely enough to stay put but will allow for easy removal.
I had put that same thing on mine and it was gone less than a week later, so I just cut down the factory antenna. It's an inexpensive solution though hope yours stays on.
Were you able to somewhat screw yours down? Mine doesn't seem to be going anywhere, but time will tell. At least there were two in the pack lol.
tyler_ross
