Antennae & roof rack
DesertCanyons
I'm trying to find out why most roof rack makers create a U-shaped cut-out in the rack outline to accommodate the shark fin, which houses the Xm Sirus radio antennae. I never activated the service even with the 90 day free trial and never plan to pay for it. I live in Los Angeles with plenty of good radio choices.
Some of the racks, like Gobi have a bar on both sides of the antennae without a cut-out. Baja Racks and Drabbits/Camelback both have cut-outs. Baja Racks says the U-shape is to avoid "Interference" with the antennae. Do they mean sat./radio reception interference or physical interference with the fin?
I want a stronger rack for lumber and other gear, without the cut-out. But I plan to buy a Baja Utility Rack because I need a low, flat rack that will clear below the trees in my driveway. I would like to ask Baja to make a rack without the cut-out. Can it be done? :eyebrows:
I've searched the WWW and found one thread here about the cut-out in aftermarket roof racks for the shark fin antennae.
http://www.toyota-4runner.org/5th-gen-t4rs/194117-stock-roof-rack-almost-worthless.html :flame:
Lots of good jokes and laughs in the thread but no one answered the OP's question. So I'm asking the same question in a new thread. If you think you know the answer, please tell me what it is. :attention:
Before you post the same old jokes, please go read the previous thread from April, 2015. :hand:
TIA
Can it be done? Of course, but is it worth the additional trouble / wait time / cost for the "custom change." Additionally you want a stronger rack. Just because the rack can handle the added weight doesn't mean the vehicle can. If you're looking for a rack that exceeds the capabilities of those out there you should probably be using a trailer.
Edit: Maybe it won't change the price at all if they are built to order.
Just phone Bajarack and you will get an answer straight from the horse's mouth without any kind of internet speculation. I've heard they're easy to deal with on custom orders, so I assume they can do it for you.
Thanks for the replies
Thanks for the straight forward answers guys. Of course, call Baja Rack. Okay, I will call them on Monday. In the mean time...
Merry Christmas with a full moon tonight. It's still Christmas here on the west coast.
On my 2016 I have no separate Am/Fm antenna, it is housed with the sat antenna. So based on that it makes great sense that they have a cut out as a metal rack would interfere with Am/Fm reception. Also do you think you are really losing that much support with the cut out? Looks fairly solid to me.
I think the antenna for the AM/FM is in the glass on the rear windows.
Correct, AM/FM is in the glass in the cargo area. Covering the shark fin antenna may also affect GPS if you have built in NAV.
Learn something new everyday, I still wouldn't believe you would loose any capability with a small notch taken out.
You wont. Not only that all these racks are built stronger than what would be safe to actually load on the roof. OP will figure this out when his unit of osb crushes the roof in.
TerryNap61
