Anybody have 1GR-FE "Data Sheet"?
JeremyB
Anybody have a PDF copy of the 1GR "data sheet"? One like this, but with the current specs (270 hp). I've found 236/245/260 hp versions. Is the data from TIS?
Just piddling around and comparing curves between the 1GR/2GR/1UR/3UR, but I'm missing the 270hp 1GR.
It is from the TIS and I have seen it, but I can't share it. IIRC, it makes a hair less torque on the bottom end than the old 1GR but a ton more at the top end (hence the extra 30hp).
You think the Performance Curve for the various engines is reasonably accurate?
Thanks, but I've found the 260hp (FJ) version already. Still looking for the 270hp (4Runner) version!
Engine info
Not what you were looking for, but it's interesting.
The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. Service weight, including fluids, is 166 kg (366 lb).
An updated version of this engine features Dual VVT-i, increasing output to 254 hp (189 kW) and 270 lb·ft (366 N·m) on 87 octane and 285 hp (213 kW) and 289 lb·ft (392 N·m) on 91 octane. Inside, the 1GR uses a "taper-squish" combustion chamber design with matching pistons to improve anti-knocking and engine performance, while also improving intake and fuel efficiency. Toyota adopted a siamese-type intake port, which reduces the surface area of the port walls and prevents fuel from adhering to such walls. This engine has special cast-iron cylinder liners cast into the block, which are a spiny type to improve adhesion between the liner and cylinder block. With these special thin liners it is impossible to bore the block. In the event of cylinder wall damage (scoring, deep protrusions, etc.), the entire cylinder block must be replaced. For increased block rigidity, the 1GR also receives a high temperature plastic insulator/protector, which fills the empty space between the outer portion of the cylinders and block material common to open deck engines. For increased cooling efficiency, the 1GR employs water passages between the bores of the engine. There are two such passages for each bank for a total of four. This reduces cylinder hot-spotting and keeps combustion chamber temperatures more uniform.
A bolt-on TRD supercharger kit is available on the Tacoma and FJ Cruiser.
Applications (with VVT-i) in model years:
2003-2009 Toyota 4Runner / Hilux Surf (GRN210/215)
2007-2011 Toyota Land Cruiser (GRJ200)
2003-2009 Toyota Land Cruiser Prado (GRJ120/121/125)
2005–present Toyota Tacoma (GRN225/245/250/265/270)
2005 Toyota Hilux (GGN10/20)
2005-2006 Toyota Tundra (GSK30)
2007-2009 Toyota Tundra (GSK50/51)
2005–present Toyota Fortuner (GGN50/60)
2007-2009 Toyota FJ Cruiser (GSJ10/15)
Applications (with Dual VVT-i) in model years:
2010–present Toyota 4Runner (GRN280)
2010–present Toyota FJ Cruiser
2012–present Toyota Land Cruiser
2009–present Toyota Land Cruiser Prado (GRJ150/155)
2010–present Toyota Tundra (GSK50/51)
2012–present Lexus GX 400 (URJ150)
____________________________________________
