Anyone heard of these wheel spacers?
I personally don't like the more universal-fit products for things like wheel spacers... I went with the Spidertrax spacers and they are top-notch. Cheaper too than what you found, I might add!!
You will definitely rub once you add the spacers... it shouldn't be too bad, but you'll need to move the fender liner forward and either trim or remove your mudflaps.
Doozi,
Where should I look to find Spidertrax for less than $117.99 for 4 plus free shipping because I will order them now.
I was planning on removing the mud flaps.
Let me know, Thanks!
Most likely these are not hubcentric either , but I haven't checked them ! I just got some from Motorsport Tech outta Sparks , Nv look under Bora after you go to their page Good prices for 2 . Different sizes diff prices , doozi will confirm wider puta more stress on components especially wheel bearings in the long run.
oljedi11950
Why did you go with 1.25's front and 1.5's rear, and which Motortechs did you order the Tacoma or FJ's?
Some of posts in lift & tire sticky will reveal more than my feeble mind , but 4wheel drive wider stance in front by about that 1/2 inch so some of the guys went wider in back actually thinking about doing 1" n front & the 1 1/2" n back so I take some of that stress off , our wheels work with both 6x5.5 so all good I believe but I did order tacoma 1s plus I like black shit better
Doozi,
Sorry... I saw "Quantity: 2" on the link for $117 and the Spidertrax are $99 for two... didn't drill into the details.
Like mentioned above they're not hub-centric which could lead to vibration, but could be completely fine. I chose the Spidertrax due to their reputation of quality, proven performance, and the fact that they're based in Colorado. The other spacers I considered were from All-Pro... also proven quality and performance.
i just order a set of these but in the 1.25"... its a set of 4 and they are made from the exact same aluminum grade as the spidertrax.. $111.00 shipped.. cant beat that.. i will let you know how they turn out.. everything the same grade materials as the spidertrax except it dont say whether they are hub centric..the seller has plenty of sales with great feedback on them so...
they arent hubcentric if they dont have that lip on the inside.. they'll wobble like mine do.. so i'm selling mine and either buying wheels or a hub centric ring
I apologize, I forgot to give feedback when I received them,
this was a horror story, less than a mile after installing them, I felt
the 4runner swaying, pulled over, the lugnuts had sheared through some threading on all 4 wheels, they were installed with an impact..
I removed them immediately and luckily the ebay seller gav me my money back with no problem..
I would not recommend them to anyone, they are dangerous.
I bought four of these off of ebay as well a few months ago and was going to throw em on and decided not to. Just had a gut feeling that I oughta go with the spidertrax spacers. After reading your post, I'm glad that I did.
i wouldn't mess with something as serious as wheel spacers. don't cheap out over 50 bucks, get the hub centric spidertrax and be happy
The SpiderTrax wheel spacers are the highest quality on the market. They are hub-centric to work with both Factory wheels as well as Aftermarket. We have them in stock and ready to ship. $97.95 per Pair.
Either Spidertrax or AllPro hubcentric spacers are the way to go. I am running AllPro's since I got them on special. If Spidertrax was on special I would have bought those.
Don't they only work with aftermarket wheels if the aftermarket wheel is the same bore as oem? most aftermarket wheels have a bigger bore to fit more applications i'd assume. so if the spidertrax ones are perfect for oem fitment then they wouldn't be for an aftermarket wheel with a bigger bore.. Am i correct or wrong? i'm not 100% sure
As long as the center rings and chamfer are the same size as oem it shouldn't be a problem.
You installed them with an IMPACT!??? NEVER install spacers with an impact! or any wheels for that matter! You always use a torque wrench! No wonder they broke in a couple miles...
you installed them with an impact!??? Never install spacers with an impact! Or any wheels for that matter! You always use a torque wrench! No wonder they broke in a couple miles...
impact was set to low torque for quick install then torque wrenched . Thank you
Rialm
