anyone plasti dip their entire 4runner??
mkristo88
Hey, I recently saw a tacoma that was plasti dipped white..Has anyone done this with their 4runner? If so, Please post pics!! Thanks,
I've dipped my runner twice, so I'm also the one with the red 4Runner. I love the stuff because I don't worry about pinstripes and its easy to maintain. NYC-Runner wheels more and can also vouch for how durable the dip is. Here are some pics of our rides dipped.
[MENTION=79132]Nyc-Runner[/MENTION] with Aluminum dip
Mine, when it was camo green
I then helped a friend do his in Anthricite
Mine now as matte red
Awesome, looks really good!! I'm thinking about doing mine white..How many coats did yours take? I was told i should do 5 coats, but i thought that sounded like a ton lol
but i'll wait for J053619 to answer that, bc he seems way more experienced with this stuff than I am lol..Hopefully it's an easy job
I went with the sprayer from DYC.com and also used 5 gallons, however it seems 4 gallons would have been good. I went with lighter coats and managed to get around 8 coats and still had dip left over. Its not too bad, but I suggest having an extra set of hands to help you out, that way you're not tripping over the cord and can finish much faster.
Don't cheap out and use 3, because you'll want to jump off a cliff when you try to take it off. I had bad experience with not enough coats on my original wheels and don't ever want to do that again. The more coats the easier it is to remove.
I'm glad you told me that, because i'm a cheapo and would probably try to get away with 3 coats haha...I appreciate your help!!
how hard is it to remove plasti dip from emblems? mine are starting to chip and peel and i want to remove it all before i try to sell my truck.
Apparently the more coats you use, the easier it is to peel off...If you only used 1 or 2 coats, good luck :-/
Here's an image to show how durable this is. I got some damage on the trail by hitting a tree.
[MENTION=142678]grave[/MENTION] If you have trouble removing it because it comes off in small pieces, use a microfiber cloth to rub it off. If you still have trouble then just spray some black magic tire wet, let it sit for 5 minutes and repeat for 2 more coats. After the 2nd or 3rd coat hit it with a pressure washer and it will come right off.
Same happened to [MENTION=66624]KCcarguy[/MENTION]... he bashed in both rear quarter panels on trees and it didn't even tear the dip! Incredible stuff!
[MENTION=77033]J053619[/MENTION] thanks for the info, i'll give it a go tonight. i finally have some time off!
well, it was a b*tch to get off, but i got it. the 5yo single coat had gotten pretty roached and had to be scraped off bit by bit. i tried the microfiber cloth with just some elbow grease and that wasn't quite working, so i grabbed a cutoff piece of walnut that i had from a cabinet i made, put the microfiber over it, and used that to scrape it off. took almost an hour to get it all off of my nissan, frontier, and SE rear emblems.
i just did my front grill last year and it has 3m, it was almost impossible to get off when i wanted it to go back to colour matched
