Anyone running 255/80/17 Tires Pizza Cutters
Was there something in the AAA report that was particularly interesting that you want us to see or are you just going to drop it here and walk off?
At least tell us why it was a "good read and an eye opener" instead of being vague.
Might be interesting, but has nothing to do with 255/80/17 specifically. It is based on All Season tires specifically, which most 255/80/17s are not.
So happy they fit - really like them so far
Fit?? What lift do you have? What tires are those?
Would like to know that same.
Those are the 255 80 coopers- I read they may or may not rub being a true 33"
I have leveled with 5100/cf spacers only. Managed to get to 3.7° too after alignment:)
I like the ride a lot - you don't feel the weight but the sidewalls wash with the width and mileage hasn't changed. Fun running over 40 psi too
Edit: added pics stock to st maxx
I'll never understand why anyone would want skinnier than stock tires. 4runners should come stock with at least 275 section tires.
Taller tire with no rubbing, lower weight, less rolling resistance.
Great off-road and economical on road
Not really puzzling
Not really puzzling
A wider tire is better for on AND off-road performance. If Rolling resistance/fuel economy is a concern, why not just buy a Prius instead? You might save 1 mpg total by using skinnier tires.
There are times when a skinnier tire is better off road than a wider tire.
Just because you are unaware of that doesn't mean it's not true.
Tire performance depends entirely on what you are doing and the conditions that you are in.
Carving canyons where lateral grip is key? Wider tires are your friend because they have more tread on the ground.
Driving on in the rain with standing water on the road? Skinnier tires have a higher ground pressure and smaller surface area making them less prone to hydroplaning.
Bounding through some dunes? Wider tires will provide a greater surface area with less ground pressure to help the vehicle float.
Rocky, technical hill climbs? Skinnier tires will put more pressure to the ground providing better grip and precision.
It all depends...
It all depends...
The fact that you had to point out very specific, atypical scenarios where skinnier tires benefit proves my point. Generally, wider tires are better for performance on AND off road.
According to your logic,Maybe you should try some 205 section tires. Clearly, 255's are WAY too wide, and 205's be a better choice. :pound:
Rocks and rain are not atypical. Some of us don't drive in mud, and have things like hills and snow to contend with. And tall tires without rubbing is a real thing if you actually drive offroad. "AND onroad"
glad you're part of the discussion for 255 wide tires. keep the brilliant comments coming
Jhunt
