Anyone Running Dobinsons UCA? Opinions?
I have about 3.5 degrees of caster on my 4runner and zero complaints. The majority of techs seem unable to know how to max out the caster during an alignment anyway, it's a huge issue where "they know what they're doing" but they don't always.
The less lift you have, the more caster you can get in it.
What UCA's are you running now?
Same story here in Phoenix.
Caps
Has anyone had issues with the o-ring caps falling off? It looks like they just press in and aren’t threaded. Is there a groove that they snap tight into?
Thanks for the reply’s,
Dave
There is easily over 100 guys on this forum running our UCA's, but I guess they haven't seen this thread.
A sealed ball joint undoubtedly lasts a really long time. Anyone with a 5th Gen running stock UCA's for over 100K miles? I doubt they have ever touched their upper ball joints. That's why we used exactly the same kind as stock, since they'll never have to be touched.
Mike, what is the highest lift you recommend I can run with Dobinson UCAs before the Camber creates tire wear from too much lift?
I am running C59-302 coils on GS59-574 struts plus a diff kit. How much front lift should that give me in theory on a 2018 SR5P with factory bumper and no winch?
I'm currently on C59-505 rears and I have negative rake. I need to lower the front or raise the rear. Otherwise, I'm getting some tire wear on outer edges despite using full adjusted SPC UCAs.
The SPC's you have now have all the adjustment to get it dialed in right. The Dobinsons UCA's have no adjustment, so you wouldn't get it as dialed with those.
I'd say your alignment isn't correct if you're still getting tire wear.
3.5" is the max lift Dobinsons suggests with their parts and UCA's. Camber can get dialed in by the tech, but the more camber it needs, it takes caster away.
You're probably at 23-23.5" from hub to fender on the front with that setup and no additional weight.
You can add one of these to both sides on the back to gain 1/2"
Dobinsons Rear Spacer, 15mm | 4Runner FJ Cruiser Lexus GX470 GX460
Hi Mike, not sure if you're still watching these older threads, but I'll post my question:
I upgraded the suspension on my 2023 ORP with KDSS to Dobinsons about 1.5 years ago. Went with Dobinsons billet aluminum UCA's and Dobinson's IMS coil-overs. I'm having a squeak or pop on both sides of the front suspension when I rock the truck while parked, and while coming to a stop at low speeds (I suspect due to the KDSS coming on at 12MPH and below).
I've felt around while rocking the truck, and I feel the vibration the strongest on the UCA and to an extent the coil-over spring. I can hear the noise and feel it on both the drivers and passenger side of the front suspension. I made sure to grease the ball joint per the instructions on install and I don't see any signs that there's an issue with it. I checked the UCA bolt and the shock bolts on both driver and passenger sides and they are tight, I don't believe they have moved since install.
The only thing I can think of is that the UCA frame bushings are binding and catching as the UCA moves. Interested to hear what you think or if you have any ideas of what I should check?
Can you post photos oh both ends of the uca bolt so I can see them and the washers?
