Anyone used rockautos “MEVOTECH”?
T4R416
Hey guys here’s my question... I found these adjustable UCAs on rock auto which specifically states for lifted trucks , obviously. I am wondering if anyone has used them they are about $400 cheaper than say SPC, they look good. I am going to be doing a minor lift soon with Bilstein 5100s and ome 285/295 ... it says these adjust camber up to 2+ degrees and caster from 0 up to 4+ degrees .. what do you guys think another thing to note is they have lifetime warranty... Napa also has their own which is about $100 more same specs etc... but I will post pic of the cheaper rock auto ones and what do you guys think?
I bought mevotech Lower control arms and while the metal looked good and matched OEM, the rubber ball joint cover was cracking and tore within a year.
I’m running their LCA for nearly 2 years.
Im not lifted and don’t off-road .
I have the same ball joint cover problem already mentioned, each side has a small tear after a year or so. Hasn’t gotten worse , I just keep checking on each oil change.
I've used their control arms on my fleet vehicles which do 70,000 miles a year each. They have been fine replacements. Surely not as good as OEM. but I haven't had issues with worn out ball joints prematurely. CNt Ttest to their functionality on 4runners, as I used them on Lincoln MKS sedans.
brendaglores
