Anyone using this 20" LED light bar? $36.90 on Amazon
What's the word on this? Does it seem like a good buy and do any of you have any creative mounting points? What do yall think about mounting led strip inside? I have considered doing that for both security and for a cleaner look. I just don't know about the heat they put off. Right at the top of the rear window was one spot I thought about and just slide down the window to use it.
I've run one on my off road buggy for 2yrs and it works great for the money. It's more of a purple light than the expensive brands but for the price they're great. I put a couple on the skid steer too to replace the round plastic floods that come on them for snow plowing.
I've been eyeing that light bar on eBay for a while. Even cheaper on Amazon- thanks for the link I just pulled the trigger. :D
1/1/16 Update: Just got it bolted up. Will review performance after I get a chance to wire it up and test it. Did not even require drilling any holes in the ARB bumper used the existing threaded accessory mounts- This light allows mount spread to be adjusted the full length of the fixture unlike the other brand with the mounts on the ends...
The specs for waterproof exterior auto lighting is IP67. You can seal it with silicone and it should be fine as long as there aren't any small openings you can't see in the body parts.
Show us this thing lit up! Then I'll get one too!
UPDATE: This unit is well reported on and an IP 67 device to boot, which means it's waterproof, etc. Ordered one just now to go behind my DIY Satoshi grill once it warms enough to build it.
Be curious to tear it apart and see what it's made of... If I had an idea where I wanted to mount it I might pick one up for giggles.
