AOB Switch help, please tell me i'm doing something stupid....
jbjones85
So I finally wired up my ARB compressor to an AOB Switch BUT the light on the switch is always illuminated (not the dash light part but the "i'm on" light). Compressor turns on and off with the switch but the LED is always on.
I have other AOB Switches so i'm assuming that the switch is defective. I have reached out to AOB but wanted to make sure i'm not missing something completely stupid.
Green on switch to 12V circuit
Red on Switch to power side of relay
Black on Switch to ground side of relay
Blue on switch --- not yet connected but will go to dimmer control circuit.
Thank you.
Thank you.
sounds like you have the red and blue wires flipped. I did something similar with a mictuning switch.. I was in a rush.
If you are using but plug connectors, connect them to the relay wires first, and then test the connection configuration with of the switch before crimping.
lindwlson982
