Are upgraded shocks worth it?
runnaz
I've read some of the posts about people putting upgraded shocks on the SR5. I've been contemplating this but after the most recent thread on nose dive and some others I have read I am re-considering just leaving stock shocks on. Opinions?
If you're concern about nose dive, the stock sr5 would have the most nose dive arguably. Aftermarket suspesion will alleviate some of that. But then you give up a bit cush on your daily drive.
I had a 5th Gen SR5 and went to Bilsteins and found the ride much better despite being firmer. Worth it? Yes, more than worth it.
Do you go off roading or purely on pavement?
I have TE with Icon stage 2. Huge improvement off road. Stiffer ride on pavement but well worth the upgrade.
I do go off road, but not any hard core off roading with this. I have a 3rd gen for that!! It is a daily driver and we use it to go camping and down side roads in the forest. Nothing too severe.
I just had Bilstein 5100s installed and they are worth it in my opinion. The front is leveled at the .85" setting, and the nose dive is reduced to what you would have with any other SUV. The ride is not noticeably harsher than the stock shocks, just slightly firmer. Shocks, installation, and alignment cost me around $550. Well worth it in my opinion if you don't need a true lift.
YES - Considering this mod only costs $300 for 4 new Bilsteins, if you do your own labor. You will need an alignment if you lift it.
Best thing you can do in addition to new LT tires.
That's a pretty good price - where?
I paid $340 shipped from ajusa.com.
Agreed with everyone on the huge ride improvement.
When the vehicle isn't fully loaded it cuts down on the head toss.
When loaded or unloaded, it cuts down on nose dive and freeway wallowing.
And when fully loaded it feels a good deal more stable.
Yeah AJUSA with Coupon Code TOY10 gets them delivered for right at $300
SR5 with Bilstein versus KDSS
Doc, how would you compare the SR5 with Bilstein and the Trail with KDSS, on road handling, lean in corners? Are they similar?
For fair comparison, when I put The Bilsteins on, I added Toytec coils for some added rear lift.
My stock TE had less body roll than my SR5 with Bilsteins (and much less than a stock SR5), but nose dive was less with the SR5 with Bilsteins versus the stock TE I'd say the stock TE had slightly better road handling, but it sat 2.5 inches lower and that is substantial affect on ride characteristics.
Overall, the Bilsteins on an SR5 made a big difference. Much better on and off road handling, better feedback from the road, more enjoyable to drive. The stock TE and the stock SR5 are really quite different and FOR ME, the difference is worth in for on road use alone (off road is obviously a big bonus).
I'd happily own an SR5 again (I think it is a great value), but with new shocks for sure.
Sorry for the mild thread jack, but I was wondering would there be any difference (ride quality, handling, etc.) at all between getting the 5100s and setting the perch higher vs. installing spacers on top of the struts? Assuming the same struts were used in both situations.
And also what are the benefits of leveling the front and back besides aesthetics?
I figured I'd ask here while we're kind of on the topic, instead of starting a new thread and then having everyone tell me to search :p
I guess it's personal preference. I changed out the stock Tokiko shocks in the SR5 for the Bilstein HD series. As firm as 5100 but no adjustments on the fronts. Ride is still comfy but firmed up in the corners and less dive.
Shocks were $321.80 from Allshocks.com.....free shipping. WELL worth it.
I'm looking to put some 5100's on my SR5 in the next few weeks, but saw that on the AJUSA site they have two different 5100's, I assume that I need two of each for the front and rear? They also dont list any for the 2012 model year, only 2011, Any difference between the 2012 and the 2011 that would prevent the 2011's from working on my 2012?
Also is $337 the best price around or is there somewhere cheaper to order them from?
From what I've found online, it seems that the HD's and 5100's set at 0 are basically the same and both given 1/2" lift. The 5100's are also nickel plated and will have reduced corrosion properties. Additionally the 5100's should be used if you're looking to lift and the HD's if you're just wanting to upgrade the stock shocks.
Is this accurate?
I'd prefer not to get any lift, level it out a touch and get rid of the head toss in my SR5.
