techno
When the vehicle is on the lift, the adjustments points are easily accessible, nothing needs to be lifted so weight is a non-issue and size doesn't make any difference. With no adjustment on the rear, there's less work to do and that's a fact. And with less work to do, the process is quicker which frees up the expensive machine for the next customer. I just feel like I'm being taken advantage of under the usual crap excuse of 'it's an suv so everything cost more'.4r and GX LX, etc... even though there are no adjustments in the rear you still base front settings off rear wheel settings (thrust angle) Plus the components are bigger, heavier, harder to access and adjust and the alignment rack still costs $50k to buy up front.
But thanks for your reply.
