Just completed the ATF exchange this afternoon after work. All in all things went pretty well. Just wanted to add some things that I learned while doing the exchange.
1. To make it easier to get under my truck to access transmission drain plug and skid plates bolts, I jacked up the front end of my truck. On the initial drain of the transmission pan I got just under 6.5 qts. I was a little surprised because most ppl said that they got 2-3 qts. I would assume that this had to do with jacking the front end up. The ATF that was in there was pretty dark. Brown with a slight tint of red. Maroon in color. (127,000 mi and original ATF as far as I know, bought the truck used with 91k)
2. I did not use a torque wrench to tighten the drain plug. Just tightened it til it was snug with a ratchet and then did an addition quarter turn. I was afraid to over tighten it. I will monitor over the next couple days. Hopefully there wont be any issues with this.
3. I have a 2004 Sport V6 with Dip Stick. I carefully (multiple times) followed the top line coming out of the passenger side of transmission towards the front of the truck/radiator. I disconnected the top line right where the short rubber section meets the metal piping again. I then connected the vinyl tubing 3/8 ID to the metal piping and routed the vinyl tubing into the milk jug. I had my helper start the engine and to my surprise ATF fluid started squirting out of the rubber hose and onto the tarp/driveway (not the metal piping connected to my vinyl tubing > milk jug)? I am assuming that this was the oil cooler inlet tube as the flow of the ATF was coming from the transmission towards the radiator instead of from the radiator back towards the transmission like I was expecting. After cleaning up the mess (luckly I only lost about 1/4 qt) I reconnected the rubber hose to the metal piping and disconnected the lower line in the same place. This time the ATF came flowing out of the metal piping > vinyl hose >into milk jug as I was expecting to happen the first time (ie. the flow of ATF was coming from the radiator back towards the transmission). So I guess my question is: Are the cooler outlet tube and inlet tube reversed on a 2004 V6 (ie. top line is actually oil cooler inlet tube so oil is pumped out of transmission towards radiator and the bottom line is the oil cooler outlet tube so fluid returns to the transmission in this line)???
