Attn: Scanguage II Owners!
I'm not sure if the tire number correlates to a specific tire to be honest. From what I understand with the TPMS programming procedure, any tire pressure sensor can be programmed to any tire number. It's possible there's a specific order that's used when they're programmed at the factory though.
With the update, everything is cleared out as the previous program is overwritten, but if you include a note asking for any particular XGauges or settings to be set before they're being sent back our update team should put them back in for you.
It's experimental in the sense that it's the latest firmware with the extra code needed to access the TPMS data tacked onto it. It's not been fully tested so there's always a possibility (even though it's a pretty small possibility) there could be a bug in there that would need to be fixed. Thus I always prefer to let people know it's experimental in case any bugs are found. Most likely it will work fine and you'll have a unit with essentially the latest firmware which won't require any updates though.
I already sent mine in so can’t add a note but would like the two Trans Temp Codes entered. I’m Dave from PA so hopefully there aren’t others.
As for which code goes to which wheel, I’m confused here. Do we also need to enter our tpms codes when we get them back to have them match 1,2, etc.?
However......our sensors also transmit tire temps (see screenshot below). If you are updating the software for pressure, can temperature also be investigated or added? Just a thought.
I believe I can get tire temperature reporting as well. I'll send the XGauges to ehcanadian to try them out and see. If anyone else who's recently updated their ScanGauge to the newer firmware would like to try what I have to tire temperature just send me a PM and I'll toss them your way.
I'll let our upgrades department know you want the two trans temp codes re-entered into your unit after it's updated.
Basically the XGauges will allow you to view the data for tire ID's 1 - 5. What tires correspond to what ID's may be random. Some people may find Tire ID 1 is reporting data from their right rear tire, while others may find it's their left front tire. That's just an assumption on my part, but I think it's a safe assumption. The TPMS registration process allows you to map any TPMS sensor ID to any Tire ID, thus any tire could be represented by any of the Tire ID's.
Ultimately to figure it out you'd just have to air out a tire then check to see which tire ID had a drop in pressure. If you let some air out of your front driver side wheel, and you see the pressure for Tire ID 2 drop, then you'd know Tire ID 2 is your front driver side tire. Once you figure them out you'd be able to then go back and change the XGauge Name to something like FLP (Front Left Pressure) to make it easier to know what a specific tire's pressure is.
Appreciate it. :thumb:
I didn't know (or didn't remember) that the XGauge Names could be changed but that should work well then. I'll play it when I get mine back.
I've been playing around with mine, and once I figured out what tire was reading to which monitor, then just put them in that order on the display to correspond, figured it would be simpler.(I was thinking about tire rotations) I'm also brand new to the scan gauge so maybe once I fiddle with it more, things will be easier
Cool! Thanks!
Once we get our updated units back, will the pressure XGauges already be programmed in as part of new software? Or will we need to get codes from you and enter them ourselves? You guys will be getting my unit tomorrow, Michael from Virginia.
I did a little more research here and it appears the 5th gens do not have TPMS in the spare tires, but the #5 TPMS is in the ECU. Would be good to have for those of use who replace wheels/tires with 5 new ones where all 5 wheels have TPMS and would like to monitor pressure in the spare.
Shipped out my ScanGauge II today for update.
Ill be testing the temp code today and will let you know!
Tested my re-imaged Scanguage II today. I had put in the mail last Thursday using regular snail non-priority mail. Got it back yesterday (Wednesday) in a USPS Priority box and very will protected. It was probably better protected than in what I sent them.
All settings were reset back to factory, so be prepared to lose your pre-existing data and renter the settings for your particular vehicle upon first booting up.
New firmware comes with two possible sets of xguages (TP1 through TP5 and TM1 through TM5). There was a note asking to email back with which set reports a reading. [MENTION=178113]ScanGauge[/MENTION] the set that worked on my 2013 4Runner LE was TM. The TP set didn't read anything. As mentioned in post above, TM5 for the spare doesn't report back a reading because my spare doesn't have a TPMS gauge.
It takes up to 20~30 seconds for all 4 gauges to register with the first one registering in only a few seconds. They read a negative number for a while and then start to show the correct reading. The pressure readings increase as the tires warm up as expected. They showed about 2 psi less than my hand held mechanical tire pressure gauge. Not sure which one is right but I think my hand held gauge is a cheap-o so my bet is on the Scanguage.
The Scanguage says one of my tires was a couple pounds less than the rest which was exactly the kind of information I wanted to know. Very happy with the quick turnaround and extra functionality. Thanks again!
PS - [MENTION=178113]ScanGauge[/MENTION] which number represents which tire? I guess I could go out and test with my mechanical gauge but its dark outside.
I am guessing:
TM1 - Driver Front
TM2 - Passenger Front
TM3 - Driver Rear
TM4 - Passenger Rear
Cool! Thanks!
The XGauges for tire pressure will be pre-programmed in, so you should be able to just plug and play.
I am guessing:
TM1 - Driver Front
TM3 - Driver Rear
Good to hear it's all working - thanks for the feedback! With regard to the tire locations we're not entirely sure. The best way to find out if you can is to let some air out of a tire, see which one drops, then fill it back up and repeat with the next tire.
Got my unit back yesterday and new tire pressure codes are working. The TM codes work on my truck. Thank you James for the updates and programming work!
Which number represents which tire? I guess I could go out and test with my mechanical gauge but its dark outside.
I am guessing:
TM1 - Driver Front
TM3 - Driver Rear
Silly me! While testing which TM number corresponds to which tire I just realized it’s going to be different for everyone. The ECU and the Scanguage have no idea of your tire rotation and positioning. This means that you will have to retest or remember the rotation order each time you rotate your wheels.
I think I’ll just paint the number on the inside of the tire after determining which is what.
On the screen I’m going to want the results positioned to match the tire’s position on the truck. FDriver = upper left. RPassenger = bottom right. Etc..
Hi Everyone,
I'm James DeLong, and I'm the engineer that worked on the Toyota TPMS XGauges.
I believe the Tire Pressure XGauges we've come up with will work on Tacoma's from 2006 - 2015. If your Tacoma is within that range, feel free to send it in and we'll update it.
I think there's a decent chance what we've come up with will work on most Toyota's with TPMS. If anyone has a non-4Runner Toyota/Lexus/Scion with TPMS feel free to contact us at [email protected] to ask about updating their unit for free to test out what we have. Would love to test this out on as many Toyota/Lexus/Scion vehicles as possible so we can be sure it works well.
James,
Any chance you'll open the cutoff for a 2007 4Runner ? Was there a CANBUS change from 2007 to 2008? I had thought 2006-2009 4Rs had the same setup. Thanks!
So which devices do we buy for a 2016?
The ScanGauge 2 is what you'll want. I believe the current TPMS based XGauges will work on the 2016 4Runner.
The firmware that supports these TPMS based XGauge's hasn't been fully released yet though, so to get the correct firmware you'll want to order directly from us at ScanGauge.com.
James,
I've been looking it over, and I believe I can expand the date range. I believe the TPMS XGauges we have should work on any 4Runner equipped with a TPMS system from 2004 to 2017. If anyone has a 4Runner in that date range and would like to get their ScanGauge updated for free to test out the new TPMS XGauges feel free to send it in! Just include a note indicating that you need the update to test out the Toyota TPMS XGauges.
For anyone who doesn't have a ScanGauge, but would like to have one for the TPMS data (or any of the other data it provides) you can use the coupon code 'T4R' during checkout at ScanGauge.com for a $30 discount. We'll also input all the XGauges we have for Tire Pressure/Temperature before shipping it out.
Thanks James!! I was about to buy a new 4R :D
THANK YOU James!
2012 Tacoma, upgrade works like a charm!
Shipped Saturday 2 day USPS, returned Wednesday, Super fast return.
Kudos again to all involved at Scan Gauge...Outstanding!
[MENTION=178113]ScanGauge[/MENTION] (or anyone on this forum) is there a function on the Scangauge II to have "presets" to quickly rotate through saved groups of 4 guages?
Now I have my tires set to the order of tire rotation (left top gauge is driver front, left bottom gauge is driver rear, etc) it would be nice to save all 4 settings saved as a preset screen. I would love to have the ability to have other user defined presets for groups of 4 gauges for things like gas mileage, performance, temps, etc.
As-is now, I have to cycle through all buttons each time I want to see the gauges I want to see at once. It wasn't such a problem before, but now that I have the tire gauges and want them to display in a certain order, its a PITA to cycle through the buttons when I want to switch to other gauges and back again.
Is this something that you could program into the next firmware release?
Hey James, I just placed my order directly with ScanGuage and threw a note in the order notes section, thanks for the discount! Can you have this programming is done prior to shipment?
Thank you, Phil Brooks
@Scanguage This has probably been answered somewhere but, can you get transmission temp with the scanguage2? 2016 4Runner.
Thundro
