Attn: Scanguage II Owners!
[MENTION=178113]ScanGauge[/MENTION] how or when will be able to get rid of the extra 5 TP gauges that don't report anything? Not a big deal but I wouldn't mind having 5 less things to scroll through when selecting what I want to display.
The quick way is to blank out the first two characters of the TXD and then proceed to save the XGauge. That will remove it from the gauge list because the ScanGauge will see the first two characters of the TXD being empty and will assume the XGauge slot is empty and move on.
Transmission Temperatures. When towing this always worries me, but it hasn't been a problem yet.
Give these two XGauges a try for Transmission Temperature:
Transmission Temperature 1
Transmission Temperature 2
Those should work, but if not just let me know. I believe one reports the pan temperature while the other reports close to the torque converter. I honestly forget which one is which though. The one that fluctuates more and goes up/down quicker depending on the load is like the torque converter reading, while the more stable one that gradually goes up/down is likely the pan temp reading.
Awesome! Thanks for the discount on the Scanguage as well. I just placed an order for one for the 2013 TE I will be picking up tomorrow.
Is putting in the t4r code sufficient to get the beta firmware or should I have included a note as well?
The T4R code is sufficient. Programmed up a few with the beta firmware that are going out today, and I imagine one of them is likely yours!
Thanks Scanguage for the discount! Just put my order in and look forward to using Scangauge to monitor the transmission during towing and for actual mpg.
Have a great weekend.
So the install of the ScanGuage went fairly easy.
Scrolling through the gauges however found some extra gauges that aren't in my manual.
Extra gauge codes were "TT".
There are a lot of the TT gauges, as well as some extra tpm gauges which we were told if they don't work we could clear them out.
So now I look at earlier post #81 above and find that the "tft" gauge is the transmission gauge I requested be programmed in at the time of my order.
The one thing I forgot to mention in my order was that I had a 2017 4runner. so would that have mattered? I did use the T4R code so that may have helped them program it.
And I guess I will look and see how to program the second "tft" gauge in post #81 above and see which one is programmed in there already.
Have yet to test drive it yet just did the setup and installed in front of my clock on the top of my dash.
Thanks for any help with the above questions.
edit; nevermind, found it "TT" is for tire temperature
False.......2014 limited with 20” wheels here and no 5th TPMS. Here is my TIS Techstream showing this.
Interesting... I have several people tell me that their Limited does have 5 sensors. I wonder where the cutoff is...
Have my Scangauge installed and it works great. Have noticed several people posting that when they installed bigger tires, that their speedometers actually matched their gps speed afterwards. Has anyone adjusted the mph on their Scangauge for stock tire size? How much did you compensate on the Scangauge? Thanks for any help, trying to avoid adjusting by trial and error....Jim
[MENTION=178113]ScanGauge[/MENTION] if I buy a new SGII from a local dealer, will it include the software update or is this still an update I need to send out for? Thanks.
We've recently released the firmware, but it can take some time before all the local dealers restock with it. If you happen to purchase a ScanGauge from a local dealer and it's not the latest firmware we'd be happy to update it for free.
Also found out some interesting information through my Instagram account...
The SR5, TRD Pro, TRD Offroad, and Trail Edition (non-Limited) 2010+ 4Runners have 4 TPMS Sensors.
The Limited (ones with 20" wheels) have 5 TMPS Sensors.
My 2015 has 5 sensors
I got my SGII updated and am loving having the tire pressure info! :) Thanks ScanGauge!
[MENTION=178113]ScanGauge[/MENTION], on my ‘18 4R, my OBDII cable is constantly coming loose from the vehicle port and disconnecting. I’d I fiddle with the cable where it connects to the vehicle, I can get it to reconnect, but then it will quickly become disconnected again. Do I need to buy a new cable? Any suggestions on how to keep it secure?
Hmmm, hard to say why exactly it's not staying on well. Normally the OBDII connection is pretty snug once it's been pressed all of the way on. If you'd like, PM me your shipping info and I'll get a new cable sent out to you. No charge for the cable since we're trying to fix an issue.
PM sent. Thank you very much! Hopefully this will be an easy fix for it. :)
so far I have not had problems. have it connected up now on my trip to the south . works great I highly recommend it .. about a year old .
I did call to get some info on how to program it ,service was great .
Quick Update!
I have been running my 5 year old Scan Gauge with this upgrade for a few months, and I have to say this is one of my favorite upgrades to Natalia!
You can really see how different driving conditions can change the pressure and temperature of the tires, and I don't have to worry about what is going on with my tires on the highway or the trail.
Also, the update time between the TPMS sensor and the body ECU is not as long as I was let to believe. I would say ~1 minute when rolling...
HUGE KUDOS to [MENTION=178113]ScanGauge[/MENTION] for this upgrade!!!
I've always meant to get my older Scanguage updated but this TPMS enhancement spurred me to action. I shipped mine back today so I can use it in my 2018 5th gen
So question for scangauge folks , say I buy a ii from say amazon I still would have to send it to you guys for an update ?
There is a chance it wouldn't be the latest firmware. We've been supplying the latest firmware to our resellers for only a couple of months now, but Amazon probably has some older units it needs to work through.
If you find you need an update, just get in touch we me and we'll get it taken care of. We try to make it as quick and easy as possible for anyone who's recently purchased a unit from one of our resellers but needs an update.
I shipped mine on Saturday and USPS is reporting it was delivered yesterday to a parcel locker in Mesa, Arizona. I can't believe how fast that was. I've always liked their Priority Mail service.
Appreciate the response & will get back with you !
