backup camera mod?
xtoy4runner88x
Hey has anyone here moded the rear camera to an on and off switch to where you can have it on when ever you want and no only in reverse?.. be intereseted to see if some has done this. im not too savy on electronics so im scared to try and figure it out..
Thanks guy
This may be another option. If you have the rear view mirror monitor, you could replace the rear view mirror to one like mine, which has an on/off switch built in. Then change the power install from the peg of the reverse switch to a peg that has constant power once you turn on the ignition.
The rear view camera comes on every time the engine starts, but then you simply hit the mirror button to turn it off. Then, while the engine is running, you can turn the camera on/off at any time. (No need to be in reverse).
So just two things. New rear view mirror. Re-install the power cord. Pretty easy. See below for the mirror I used.
The rear view mirror sale.
The item I bought is from Rostra Precision Inst. Inc. Model 250-8804 (Slim line 3.5 monitor)
http://www.rostra.com/products/magn...tomotive-backup-camera-systems-by-rostra.html
I talked to Thomas in Tech Support, 1-800-732-4744 At Rostra. He told me this is the same kit that is sold to SE Toyota at the Port of Call, except this has the 3.5 inch screen vs the 2.4 inch screen Toyota uses, but everything else is the same.
Thomas recommended I call Brandon Disturbing, who is the sole distributer of Rostra Product. Contact “Joe” at Brandon, 1- 877-402-3944. I did so, and he sold me this kit for 471.15 plus shipping. The dealer quoted me 665.00 for the same kit, using the 2.4 inch screen vs the 3.5.
Lakeland Toyota Quoted me 189.00 to install THEIR kit. I called him back and asked him if it is the same cost if I bring in my own kit, the only difference being the mirror has a bigger monitor. He said yes, if after his installer looks at it and confirms all the same.
250-8804-CCD
Magna 3.5" TFT LCD Slim Rear View Mirror Monitor and 1/4" CCD Color Camera
Click image to enlarge...
Features
• Auto Dimming with 16:9 Aspect Ratio
• 1 Video Input
• Reverse Override
• High Resolution Display
• 30' Extension Harness
• OEM Approved
• 3 year/36,000 Mile Warranty
Download installation instructions.
Includes CCD Camera
I do not think so. I think another member here had the same issue and added a switched rear view mirror cam. That was sometime ago and my memory might be faulty on that one. Nonetheless, you might consider that as an option also.
See above. I was only talking about Rear view mirror. Those with video in head units Stereo/Nav, different wiring I am sure. Hence the reason that other member added a second camera and a rear view mirror monitor. I am not saying that is the only solution, others have done other things with the center stack displays, I was only suggesting an option. Be Safe.
While we're on the subject, does anyone know if the video signal from the camera is composite and a good place to tap into it? I'm installing an after-market Alpine nav system and would like to send the signal to both the mirror (where it currently goes) and the Alpine head unit as well
Grant, check the end of the aftermarket stereo thread. I put some pics in on how to tap into the appropriate wires.
I left my OEM rear camera > Nav as is so I'm not sure. My new front and rear cameras going into the rear view mirror are both aftermarket.
Thanks.
Now, does anyone know where in the RM are instructions to disassemble the overhead console for a TE? It doesn't have the sunglasses compartment and there aren't any visible screws.
All that lighting crap just pops out gently. Get a metal nail file or similar and in the center section insert file at the aft edge. Pop it down to expose.
Thanks Reata, but there's more to it than that.
I found the info in the "LIGHTING (INT): ROOM LIGHT (for Front): REMOVAL (2010 4Runner)" section
First is to remove the drive monitor switches then remove 2 screws then the map light assembly can be carefully pried loose from it's clips.
