Behind grille light bar complete kits
Anyone have one of those 10% off coupons? :becky:
Try CART10
Can't remember if that's what I used...
If that doesn't work shoot me a PM.
I do believe you will be pleased with the product. I have not yet installed it but everything seems top-notch so far. I temporarily hooked up all of the wiring just to test it out the other night and everything fired up nicely and looks great!
Try CART10
Yep, that worked. Thanks for the follow up.
Questions
I will admit, I like the look of the behind the grill, three separate LED lights.
I would like to eventually add this to my 4Runner, but I have a few questions ...
1) How did you wire up your lights? Did you run wire along the inside of the engine, push it through the firewall, and have some kind of switch on the console? What kind of switch do you use, and can you provide steps with pics? Or, did you splice into the low beam headlight wiring and the behind the grill LED lights come on when the low beams are on?
2) Are the three separate LED lights mounted to the grill itself, or separate brackets attached to the top of the bumper?
3) When do you use your behind the grill LEDs? Do you use them when off-roading, if spliced into the low beams, typical driving mode, etc?
Thanks!
Thanks!
Most light bars come with relay harnesses and a switch. Originally I wired my light bar and ditch lights to OEM style switches which I have for sale. I removed those and am now using an sPod to control all my lights individually and together.
The brackets do not mount to the grille, they mount to the bumper supports or frame.
Do NOT drive with LED's on as low beams or on road driving, I only use mine on back country roads and roads where deer are prominent, I would never drive at someone with my lights on because they'd be blinded
AndiGarage
