Best door ding slider?
css899
I am looking to purchase some sliders for my 02 Sport. I would like to get a set that protect well against door dings also. Getting tired of people opening their doors into me. Any idea which sliders would be best?
Any slider that sticks out far enough past the doors will be fine for that use.
CBI is running a special on bolt-on sliders right now:
Todays deal is a set of flat CBI Bolt on sliders
Sliders come powder coated black
Reg. $584.99 Now only $449.99
These CBI Off-road rock sliders come powder coated black and are built for the true OFF-ROAD enthusiast! Each slider is construction by one of our skilled fabricators out of Hot Rolled Electric Weld tubing (H.R.E.W. 1.75″ x .120 wall), with ¼” thick mounting brackets. The included grade 8 mounting hardware make these sliders rock solid and durable to handle whatever punishment you can dish out. CBI offer sliders with the most evenly spaced stand offs to the frame that give them the best performance and strength compared to other manufacturers. (No long unsupported length near the back end) The rock sliders can also be used as a lifting point for a hi-lift jack and will support the full weight of the vehicle. Each slider can be ordered in a variety of configurations to meet your needs or we can custom build the perfect set for your application. The bolt on application makes installation easy and doable for all.
Call to order Toll Free: 866-522-0697
And Savage makes sliders too, that are a little cheaper, but are weld-on, so I'm not sure that's something you would want to do.
Are you sure you want to add sliders if the only thing you'll be using them for is to prevent door dings? It seems like a cheaper option would just be to park away from everyone lol.
I have trail gear sliders and you can mount them as close in or as far out as you like. My tires stick out past the body about 2", and I mounted my sliders so they were almost even with the tires.
Next time around I'll be mounting them flat like a running board and they'll probably stick out even further :o
Yip. I have mine set up to around even with the outer extent of the flares, although honestly my stupid limited cladding would be the only thing being hit by a door anyways.
IMG_00001384_hdr_zpsa3edb640.jpg~original
I got Trail Gear sliders from Addicted Offroad.
Cost was $176.00 shipped to the door and I mounted them with about 1 degree of upward tilt, basically flat.
Has saved my drivers side door twice that I know of because I saw it.
Last one was about a 400lb woman winging open a huge Cadillac door right as I walked around to get in, it left a pretty big half moon on the edge of her door.
I couldn't help saying, "Bet you wished you hadn't done that huh?"
Didn't even chip the paint off my slider, it actually hit the grip tape and barely left a mark.
Her door however had a nasty half moon.
Already spent close to $400 on paintless door repair. Doors are perfect again. No shortage of door dingers on patrol where I live. Doesn't matter how far out I park. Hoping a nice pair of sliders will help.
