Big 3 kit is here!
If you follow the writeup, it's pretty simple, tbh. It was my first time doing anything like it. This certain writeup doesnt necessarily have you remove the existing wiring, but adding the Big 3 to coincide with the original wiring to help, minus the weak ground to fender. That small ground wire to fender definitely is replaced.
The writeup is very detailed, so it may seem overwhelming, but it's quite easy. He just gives alot of information so you have an understanding on what the purpose of this upgrade is for. Good luck.
Awesome. Thank you.
[MENTION=120147]Mighty Buffalo[/MENTION] Can you elaborate on the issues you’re experiencing? I just ordered a stage 1 kit for my 2000 and wanted to be prepared
Really you just need the alt => battery pos, engine => batt neg, body => batt neg. in the instructions, it says to move the 8ga cables around that go to the fuse box, don’t. The kit has copper-coated aluminum wire, which is cheap and prone to breaking and fracturing, and it’s inferior wire.
The xScorpion terminals look cool, but I could not get the neg to work at all, and the pos is corroding out.
Aside from product issues, he wouldn’t respond when I told him I had a problem with the terminals. In a couple other threads and group buys, he’s taken months to years to deliver product, and he’s banned from TacomaWorld.
I see talk about "the big 3" all the time but can't seem to find a post explaining what it actually is. Is it just replacing oem wiring with better wires?
044runner4
