Big Tires?
4RNR4BB
SO my dad bought a 89 4wd truck and it came with some pretty sweet wheels and tires. He doesn't like tham and I was wondering would they fir on my 4runner. The tires are 305/70/16 on a 16x10 wheel! Are these too big? What size tire could I use on these wheels? I don't know offsets or back spacing, but are they too wide?
Matt
it will stick out past the wheel wells. to keep the 305 you will need a lift. you might need wheels spacer. also what truck are these coming off cuse chevy/dodge truck have different bore size, but same lug size. (6x5.5 i think) if you do run wheel spacer dont worrie about the bore size.
The wheels are coming off a Toyota truck. So how much of a lift? I was thing about teh Sonora2 Steel 2" lift, you think that would be enough?
get the SS 1.5 kit and a 1" body to clear, you can do some inner fender cutting and modding (within the realm of stock looking) and get them to fit without a bodylift.
The 1.5 kit is for 4wd only according to their website. I know why lift my 2wd? I don't know I guess for looks unless I need it to clear these wheels.
Update:
Okay so the tires are off my dads truck and I am really thinking about putting them on my 4runner now. I rolled them up next to my truck and it looks like i will definetly neeed to lift it up. So assuming I do the lift, should I regear as well? They are 305/70/16 and my 4runner came with the upgrade 16" wheels. I daily drive my 4runner so I am wondering how much these wheels and tires will effect my driving.
It's not necessary to regear but your gas mileage will significantly decrease. I was around 300 miles a tank with stock tires and now I'm around 230 miles with 33's which is roughly the same size as your 305's.
305/70/16 are equal to 35"s, im pretty sure. with a 3 inch lift you can fit 33"s, so with another 2 or 3 inch BL you could fit these size tires. But you would def. want to re-gear to either a 4.88 or a 5.29. Without regearing your gas mileage will go down and also power since its a 2wd?
33's are usually 285's
285/75/16 and 305/75/16 are both 33's. The 305 is just wider.
315/75/16 is a 35" tire.
The SS kit is good. I didnt buy mine from Steve because I was able to piece it together over time for a lot cheaper.
I currently run 285/75/16 Nitto Terra Grapplers on stock Limited wheels and dont have any issues with it. Only rubs the upper control arm at full droop. Its not that much of a problem anymore now that it is the tow rig for my 1st gen truggy.
Re gearing to 4.56 could be an option.
Do you have any pics of your rig? Maybe some good tire fit shots?
Yup...I will get some pictures up on this thread for you tomorrow. I have to upload all the pictures from this weekend with the new tires.
delislerebecca
