Bilstein 1.75 Front, 1 or 1.5 Rear Spacer 265/70/17s
Nickelly
Anyone have a pic of 1.75" front, 1" spacer in the back with oem size tires, 265/70/17. Planning on doing this but wont be going bigger on the tires for a while since I bought my ridge grpplers not too long ago.....
I have the black trd 17" wheels.....
Ive ready through what seems like 100 threads with no exact answer. I appreciate anyone who takes the time to answer this even though its been done 10k times...
I have the front set for 2" and the rear with 2" springs with 265/70/17 Grabber AT2
I'm at 0.85 with no spacer in the rear. It looks almost level, a slight rake. If I went to 1.75, I would go with 1 inch spacers in the rear. Should be almost level, with a slight rake. IMO 1.5 spacers would be too much.
I also have AirLift bags for when I add a load to keep it level.
not spacers but 1.5” saw springs for the rear
Did you happen to measure how much lift you got? I've heard of those giving closer to 2 or 2.5 inches but am thinking about them currently for part of a 6112/5160 combo...
Look up threads with my pics... I’m at 1.75 front and 1 inch rear spacers...
No specific measurements, but from my estimate, I believe I got 2" right after the install. Then, eventually settled to 1.5" after a few hundred miles.
5100 Bils' all around
not exactly what youre asking but.... 1.75 up front, 1.25 spacer in rear. On stock 265/70/17's (for now)
socalka-albums-socalka-s+runner-picture51652-t4r-carwash-5100-bilstein-1-75-front-1-25-spacer-rear.jpg
...wow! look at me responding to old posts.
Went 6112 2.5" (7/5) front and T13 rear. got a true 2.5" lift in the front and 1.25" in the rear. Stock tires. Will eventually go new UCA to help with the alignment.
Where to find 1" rear spacer
Where can i find a 1" rear spacer?
I am putting the adjustable bilstein 5100s on all 4 corners soon, front set at 1.75", but I am being told that no one makes a 1" rear spacer for a 2018 4runner. I can only find a 3/4inch spacer or a 1.5inch spacer. Or stack 2 OME trim spacers on each other, which im trying to avoid. Any input or options? Know anyone that does customer spacers? Thanks!
One option https://www.metaltech4x4.com/ironman-4x4-4runner-gx460-2010-trim-packer-rear-25mm/
Search cornfed spacers. I have their 1” spacer.
Deka
