Bilstein 5100 and Old Man Ema Spring
CT_NGO
Hey T4R family. I been talking to Toyteclift about this setup. They say it's a no go. What do you guys think? I found a good price for both of this item. That is why I'm think about this setup. I'm looking for a 3" inch lift without spacer and under $800 . I can get both item under $750. Your opinion please?
6112's give you 2.75 at the highest perch
I have the Toytec listed in the classifieds section and will be listing my Bilsteins soon. Both brand new in box for $320. I went with the BOSS setup due to adding bumper and winch.
Please. Do what you want of course but they did not say it was a "no go" they said they could not recommend them because they hadn't been tested with their shocks. BIG difference. Guys mix and match all the time. And the truth is a spring is a spring in this case. Just different coil diameter for different loads. Neither is progressive, just linear.
Thanks 1engineer
They (Toytec) most likely do have good testing and feedback of everything they sell. Yeah, they're not saying it won't work. Maybe their coil is a better choice, resulting in a better ride, based on their collective experience?
But if someone said they're going to run OME shocks/struts with our coils, or our Dobinsons shocks/struts with OME coils, I'd probably recommend against it for a few reasons.
1. We don't know what it will ride like.
2. We know what lift heights and results our full products will give.
3. Yeah, they were never tested together. If you run a heavier/firmer coil, you may have softer shock valving. Or the other way around too. So mixing and matching could yield a "not very nice ride" at the end of the day.
We had a local guy running our 6" 80 series complete lift with resi shocks, and he insisted on changing out our reservoir shocks for some Fox shocks, based on someone's advice. The ride completely changed and he wasn't satisfied at all anymore. He had already sold the Dobinsons MRR shocks though, so he was out of luck.
I know that some OME coils are tapered and turned different to stock to work with their struts (200 series Land Cruiser for example), so OME generally doesn't advise using their coils on other brands of shocks or struts.
I think this is also why so many people ask for full specs before purchasing these days so they can figure things out for themselves and guesstimate the end results.
They (Toytec) most likely do have good testing and feedback of everything they sell. Yeah, they're not saying it won't work. Maybe their coil is a better choice, resulting in a better ride?
Exactly. Good post.
I was just running Bilstein 5100s and Old man emu 885 springs in the front. With 5100s in back with the 895 spring. I had the Bilsteins at the first setting and got a good 3" out of the set up.
Are you willing to ship the Bilstein? I got family in Columbus,Ohio I can ask them to pick it up if your willing to go cheaper. So you don't have to pay for shipping.
