Bilstein 5100
skillbill
After research I order the 510” with OME 883 springs and OME 891 for the rear. My question is what perch to use on the front? Want a good combo of lift along with good ride.
not enough info to give you a good answer. what are you trying to achieve? what size tires, how much additional weight are you carrying,ie bumpers, camping junk etc. give us a rundown on your truck and what you want to do with it and we can give you a better answer.
The 5100's were designed for stock coils when adjusting their perch.
Its recommended to NOT preload aftermarket coils with them. Just set it at 0, and you should be fine.
I will be adding a front bumper in the future. Winch? And will be adding a storage system in the rear.
erinobr2000
