Bilstein 60mm BTS System
[MENTION=103267]Saker[/MENTION] - thanks for essplainin... That is a bummer
Keep us posted if you find out any information from toyotec
[MENTION=75328]DannyLlama[/MENTION],
No Problemo!
Will post when I get some feedback from Toytec.
Wow that kind of sucks as the BTS's look pretty sweet! So basically the 6112 kit has the same spring seat step adjustments as the 5100 adjustables ,and not ideal to adjust,with a bigger shock 60mm body and included spring .
Maybe they didn't want to step on Toytec's toes which has the Boss adjustables using Bilteins's threaded body shocks. The Boss Coilovers look like they have bigger shocks then their Ultimate kit,which have the 46mm 5100's, but not sure if they are the 60mm's.
Actually, the Boss COs are Eibach springs and shocks. That is what I was told directly from Toytec.
I am beginning to like this set up more and more. Saker, thanks for finding that info. January will be interesting...
I'm still trying to find the best way to avoid buying something that I have no idea what the ride quality will be once its installed....
The OEM suspension is OK but it's not great on my TEP.......
Would the 6112 glide over irregular road surfaces / road humps / bumps / pot holes / ruts etc without tossing you around? Not expecting it to be a trophy truck but the closest I can get there the better! :)
Would the 6112 be the best bet? :spy:
Test drive a TRD Pro. That will give you the closest approximation. TRD Pro's suspension is basically the same as the 6112 but can also be adjusted like the 5100 series, from what I've seen so far. My opinion... the 6112 will be softer than the stock TEP. I have not tested a TRD Pro to confirm.
Here is Bilstein at the Off Road Expo vid: Bilstein 6112
sounds promising! I put 5125's on my pathfinder and it didn't seem to really ride that much better although the truck is 20 years old....
really want to try before I buy but its tough with these products since you really dont know what u are getting until you buy and install.
Really don't know if you can compare the 2 series....I think the performance is wayyyyyy different!
hey everyone - my name is Chas and Ive been a member previously with a sponsor I used to work for, but now Im doing my own thing.
I have a few toyotas including an 03 4runner, 06 tundra and 06 tacoma here at the shop. Ive been working with Bilstein on the development of these shocks for some time now and wanted to chime in with some spy shots of the prototype units as well as let you know that so far these shocks have performed like much more expensive units do. With all the testing done the setup will be dialed in perfectly. They are a large improvement over 5100s, which are already night and day better than stock. These will be a hot shock in 2015. :rockon:
Here is the full article , it would be better if you would have included the last sentence that is in bold in my posting!
What is shown in the photo for the front is the BTS System, not the 6112's.
Bilstein 6112 Coilover Spy Shots!
By Chas Moore on December 15, 2014 in Bilstein, Ford, New Product Announcement, Offroad, Tacoma, Total Automotive Performance, Toyota, Tundra
Designed for the serious off-road adventure seeker, the all-new BILSTEIN 6112 Series kit is the ultimate suspension solution! These are massive 60mm coilovers that feature preset c-clip style height settings, new springs and cost under 750 for the pair. Total Automotive Performance has been assisting in the development of these coilovers directly with Bilstein. We will be the first to offer these new coilovers and will be taking preorders next month.
Product Highlights:
•Large 60mm monotube for increased oil capacity, cooling, and long-term durability
•Offers 0-2.5” of adjustable lift depending on the application
•60mm digressive piston for improved ride comfort and control over rough terrain
•Utilizes a high quality OEM lower mount for long-term durability and a perfect fit
•Custom engineered cold wound linear springs for enhanced vehicle control
•Monotube design for consistent, fade-free performance
•Application specific for maximum performance
•Reuses OEM top mount and rubber isolator
•Made in the USA
Kit includes (2) front 60mm shocks, (2) spring seats and (2) springs
Check out how beefy they are!! (These are prototypes with no coating and a threaded shock body and are not representative of the final product.)
Thanks for posting anyway!
But what springs? This comes with front springs, right? So what rear springs work best?
EDIT: Let me correct my wording, I was addressing the question on the rear springs.
The TRD Pro Suspension utilizes the rear factory springs. I guess it depends on what you want to accomplish in the rear. You want standard rear height use the OEM, if you want more lift in rear...that you would have to see what fits your requirements.....
The TRD Pro Suspension uses Eibach 620's up front & The Bilstein 6112 is supposed to be a kit including Eibach 620 springs as well.
DJNutshell
