DannyLlama
Elite Member
[MENTION=103267]Saker[/MENTION] - thanks for essplainin... That is a bummer
Keep us posted if you find out any information from toyotec
Wow that kind of sucks as the BTS's look pretty sweet! So basically the 6112 kit has the same spring seat step adjustments as the 5100 adjustables ,and not ideal to adjust,with a bigger shock 60mm body and included spring .
Maybe they didn't want to step on Toytec's toes which has the Boss adjustables using Bilteins's threaded body shocks. The Boss Coilovers look like they have bigger shocks then their Ultimate kit,which have the 46mm 5100's, but not sure if they are the 60mm's.
...The 6112 Coilover Kit should be available in Jan 2015 with a MSRP of 799.99...They said they will not make a BTS kit..
I'm still trying to find the best way to avoid buying something that I have no idea what the ride quality will be once its installed....
The OEM suspension is OK but it's not great on my TEP.......
Would the 6112 glide over irregular road surfaces / road humps / bumps / pot holes / ruts etc without tossing you around? Not expecting it to be a trophy truck but the closest I can get there the better!
Would the 6112 be the best bet? :spy:
Here is Bilstein at the Off Road Expo vid: Bilstein 6112
sounds promising! I put 5125's on my pathfinder and it didn't seem to really ride that much better although the truck is 20 years old....
really want to try before I buy but its tough with these products since you really dont know what u are getting until you buy and install.
hey everyone - my name is Chas and Ive been a member previously with a sponsor I used to work for, but now Im doing my own thing.
I have a few toyotas including an 03 4runner, 06 tundra and 06 tacoma here at the shop. Ive been working with Bilstein on the development of these shocks for some time now and wanted to chime in with some spy shots of the prototype units as well as let you know that so far these shocks have performed like much more expensive units do. With all the testing done the setup will be dialed in perfectly. They are a large improvement over 5100s, which are already night and day better than stock. These will be a hot shock in 2015. :rockon:
What rear suspension springs and shocks would work best with this?
But what springs? This comes with front springs, right? So what rear springs work best?
