Bilstein 60mm BTS System
The rear springs on the TRD Pro are the same as the stock Trail. The rear shocks have a remote reservoir though. The fronts are digressive and softer.
So for my '03 V8, would it be best to leave rear springs stock or change to something like an FJ spring?
So would these 6112/bts be rebuild able or tunable? Also do either of these come with the upper shock tower mounts. If not where can I get some besides the dealer. Did they really disco the 5160 rears for the 5th Gen. Thanks for your input guys. Was going to get the fox 2.5 but found out that the bearings are not the way to go for my aplication. Any idea on a real release date yet. I want these things yesterday.
The Bilstein website says they are "Lifetime Warranty" item. They would handle that and also they will tune them to your specs is you desire to pay the price.
(1) No, they do not.
(2) Dealer or someones take off shocks that have replace with another complete setup.
No, according to this just published from Bilstein.
I posted this link a few posts ago, did you look at it?
You can look them up here: http://cart.bilsteinus.com/pdfs/off-road.pdf
10-15 4Runner
6112 = 46-227294
5160 = 25-227611
Real release date.......Hmmmmm..........Bilstein is saying beginning of 2015.
Is that real, we'll see!:noidea:
Well, you can't have them yesterday, you will have to wait just like the rest of us! :faint:
I really wish there was a way to test these out before buying as anytime I buy shocks / coilovers its a crap shoot based on reviews and opinions of others which is very subjective....
the 6112's would allow for a few inches of lift in the front and you'd have to get bigger springs in the back right to level it?
......really want to try before I buy but its tough with these products since you really dont know what u are getting until you buy and install.
This is what you stated in post #51
No matter how many times you state this, I don't think this is going to happen unless you find someone that has them installed on the same application you have to determine you answer. I don't think Bilstein has this type of program available, but if they do let us know.....
....the 6112's would allow for a few inches of lift in the front and you'd have to get bigger springs in the back right to level it?
Range of adjustment by spring perch clips are 0-2.5"
The easiest way to answer your own question is to go measure from center of the hub to the top of the wheel well of the front and rear......then compare your findings!
Only adjust up until you reach level.
Most people if I recall correctly acheive level @ the 1.75" setting.
According to Bilsteing these are the setting of the lift postion og the perch settings:
2.5"
1.75"
.85"
0"
I would at least switch to FJ rear springs. IMHO, the slight rate increase not only helps when loading the 4runner heavy, it also seems to ride better unloaded. The 4th gen OEM springs are too soft.
I've also been digging the 1.5" SAW springs on my 5th gen but they are taller and a little more stiff than the FJ springs. All of that is ok because my 5th gen weighs more.
[MENTION=118252]Chas of MRT[/MENTION],
Can you include any interested parties here at T4R.ORG if you do a group buy for the TacomaWorld guys/gals??
Here is the full article , it would be better if you would have included the last sentence that is in bold in my posting!
What is shown in the photo for the front is the BTS System, not the 6112's.
Bilstein 6112 Coilover Spy Shots!
By Chas Moore on December 15, 2014 in Bilstein, Ford, New Product Announcement, Offroad, Tacoma, Total Automotive Performance, Toyota, Tundra
Designed for the serious off-road adventure seeker, the all-new BILSTEIN 6112 Series kit is the ultimate suspension solution! These are massive 60mm coilovers that feature preset c-clip style height settings, new springs and cost under 750 for the pair. Total Automotive Performance has been assisting in the development of these coilovers directly with Bilstein. We will be the first to offer these new coilovers and will be taking preorders next month.
Product Highlights:
•Large 60mm monotube for increased oil capacity, cooling, and long-term durability
•Offers 0-2.5” of adjustable lift depending on the application
•60mm digressive piston for improved ride comfort and control over rough terrain
•Utilizes a high quality OEM lower mount for long-term durability and a perfect fit
•Custom engineered cold wound linear springs for enhanced vehicle control
•Monotube design for consistent, fade-free performance
•Application specific for maximum performance
•Reuses OEM top mount and rubber isolator
•Made in the USA
Kit includes (2) front 60mm shocks, (2) spring seats and (2) springs
Check out how beefy they are!! (These are prototypes with no coating and a threaded shock body and are not representative of the final product.)
Thanks for posting anyway!
I am not sure how posting links here is going to be received by the mods so I left it out, but I should have posted that information. I took these out to Barstow and ran the MORE 25mile race course. The shocks did not flinch. I am working on a full writeup, but we are still working on the valving.
Will have to check with the mods! Total Automotive will be the first in the country to get them and will be offering some awesome pricing on them for you all.
Regarding the release date: The 05+ Tacoma, FJ, 03+ 4runner & 07+ Tundra are in production now, we should be shipping last week of Jan.
[MENTION=118252]Chas of MRT[/MENTION], could you comment on what would an appropriate rear spring for an '03 V8 4Runner if I put the 8112 on the front?
Thanks for posting.
If you do a group buy on the TW we could go there or if the Mods allow you to become a sponsor, I think you could do one here....
MODS, can you chime in here?
The rear shocks would be designed to work with the factory units, although the valving would work great with an OME or ICON rear spring.
DJNutshell
