Bilstein/883 and FZJ80 springs/shocks - Upstate, SC
89s rule
Member
front: OME 883 springs and 5100 Bilstein front shocks,
rear: 80 series front springs and factory 80 series shocks, the rear shocks need to be replaced as they leak but could get you buy until you could afford a new set. ( I might have access to another used set of rear shocks.)
I think the front shocks need to be replaced or rebuilt. If you have a wheeling rig and not a DD they would probably be OK. I replaced them with some 20K mile OMEs and the same springs and they smoothed the ride out. New tires improved it more as well.
I'll take $300 + shipping on the complete kit.
Front uninstalled before OME going in: (No cleaning involved just pulled them off after all the nasty weather we have had.)
Rear Springs:
The rear springs are pending local pick up.
I have had a few common questions about the fronts.
The fronts have ~ 60K miles on them.
I replaced the following in stages within 2 months of each other and they each improved the handling, smoothness, and comfort of the ride some. Because of this the shocks/springs might be fine for your use. I bought a complete suspension and swapped everything while I was getting everything set up for more of a DD.
Make an offer on the front setup.
Zett
