10ac
http://www.toyota-4runner.org/attac...5140-201983a7-4116-4798-a5f9-2f23d7251ac0.jpg
Wheres the bags of parts like VmaxEngage posted on page 9? I thought the tophat was in one of the bags of parts.
No top hats. They were spring seats.
I ordered new top coilover plates from amazon for 21 bucks each. They were KYB. Not worth the hassle removing and reusing old stuff as well as old coil bushing/isolator. Go check amazon fellas
https://www.amazon.com/gp/offer-listing/B00C7S0KA8/ref=dp_olp_all_mbc?ie=UTF8&condition=all
O!!! Received my kit!!! Damn it’s beautiful! I did have a issue tho. Received the box with damage. Also the box to the rear shocks in the box were damaged. Items looked ok. I did wanna take precaution so I called Olathe Toyota to make them aware because what if something starts leaking or whatever. They said they notated it and refunded my shipping costs because of the issue.
I did the same thing on top hats. I decided to install later, so I ended up ordering a set of the same top hats. Makes swap much easier.
Anyone concerned with KDSS and this kit? Don't be!
I have the TRD Pro version of this kit. Its the same kit from everything I can tell, down to the rear rest mount.
I have the toytec top 1/2" spacer. Im sitting at 1.5" of front lift with both driver and passenger coils on the bottom setting. I did have to add a OME 10mm spacer in the passenger side rear due to lean. I'm within 1/8" now driver to passenger side.
Hope this helps.
Why did you have to add spacer Asugm? Why do you think this is happening? How tall are you sitting? Is it almost 3” of lift ? What size tires are you running?
I did not "have" to add it. I added it to give about 3/4" more lift and about the same in down travel. Its the most you can get down travel wise with stock UCAs, I installed, uninstalled, and then reinstalled the kit 3 times to get it where I liked it.
I had the toytec full kit first and drove it for a month. Uninstalled the toytec kit, drove for a month, then put the top plate spacer back in and its where "I" like it.
Suspension is subjective like many things and I like it this way but others may not. Ride is plush not firm or truck like, better than stock all around, but still has nose dive, otherwise it handles the stock weight well.
I have put of 30k miles on the kit with about 2.5k being offroad. No leaks no issues and the rear res mount is still holding strong.
I do not know what you are referring to when you ask why I think something is happening.
I am at 1.5in of front lift and 1in in the rear.
I run a 255/80R17 Cooper St Maxx.
What I meant about the question, “ why is this happening was referring to the lean that you were having on your rig with the passenger side which cause you install the 10mm OEM spacer”. That was all.
Anyone here have the bilstein 6112’s new uninstalled? Not the Trd Pro 6112.
I’m needing a measurements to the 6th notch and a measurement to 7th notch so I can have my machinist make me some lower spring perch spacers so I can get 2.5” of lift. Thanks
Might only be able to get the rear on today. I’m not sure exactly how to mount the resi holder other than the one angled bolt. Zip tie should hold until it can be figured out.
The frame has that threaded hole, does the top bolt just not thread into the frame to keep it mounted like in this pic? Taken from another thread of a Pro.
This attachment might help some people for resi mounting.
I have KDSS. There was no thread on the upper hole for the rest mount. Had to improvise and use a river nut insert. Could be that they use a different frame for KDSS equipped. My buddy with SR5 had threads.
Sent from my SM-G935T using Tapatalk
Perfect!
So I wonder why mine doesn’t have that hole threaded? Wonder if it’s cause I have kdss?
