calcrc
invest in bitcoin
<a href=" https://bitcoinstock.us.com ">bitcoin investing</a>
<a href="https://bitcoinstock.us.com">is bitcoin a good investment 2017</a>
Is this a spam ??!! Can you ban this person pleasd ?
invest in bitcoin
Haha, that dealer is 15 minutes from me.
We are neighbors (not literally) :hello:
I've been away from here after owning 2 FJs and a Tacoma, but I'm finally back in a 4runner as of yesterday.
I still can't make up my mind on what to pair my new TRD Bilstein kit with for a bit more lift.
Option 1: Toytec 2" TRD PRO kit
Option 2: Toytec 1" Spring Perch Spacer + 1" Rear Eibach Springs
Option 3: Toytec 1" Spring Perch Spacer + 1.5" SAW Rear Springs
Ive always heard anything over a 2.5" front lift requires new UCA but the TRD PRO guys are running Option 1 above which, since they start 1" higher in front from factory, it would give ME (2016 TEP) a 3" lift from my current suspension in the front. Would I need UCAs? I assume not since TRDP run it without issue, right?
Re: Option 3, Ive also read the SAW springs lift closer to 2". Id REALLY like to find a TRUE 1.5" rear spring, if possible. I realize Im kinda splitting hairs here, but it's what I do.
Yea, I forgot to mention I knew the Toytec 1" perch spacer = 2" of lift once I swap in the TRD Bilstein kit. Im good with that in the front. Just trying to iron out the rear.
Its kinda dumb that I can't buy the perch spacer and the T13 coil from the same vendor. Wheeler's has the T13 obviously, and some Toytec parts, but not the TRD perch spacer. Toytec has the spacer but no Wheeler's products.
As far as I’ve researched, they’ll be fine with the T-13s. I have the T-13 with my 5100’s and works great.... I believe the 5160s are the same length as the 5100s.
Below is a long thread covering lifting the pro model 4runner which basically has the same suspension as this kit has. Plenty used 1.5-2” rear lift coils.
That wheelers spacer is a similar preload spacer but will not fit the 6112s....too small of diameter. The 6112 is a large diameter shock body (~2.5”). The Toytec 1” lift spacer that was referred too in an earlier post is made specifically for the 4runner Pro which has the same 6112 fronts that this FJ kit has.
http://www.toyota-4runner.org/5th-gen-t4rs/208900-trd-pro-lift-question-64.html
Post 34 will show that Wheelers 3/4 replacement coil isolator used on a trd tx baja which also is a trd 6112 setup.
https://www.tacomaworld.com/threads/2013-trd-baja-2-taller.269063/page-2
Cool.... good find...way less expensive than the aluminum Toytec perch spacers. I didn’t realize these poly spacers (fit on top of coil) were large enough diameter to fit the “stock size” coil as well as the larger 3” trd “eibach” coils.
Thanks for posting.
So according to that info, which product from Wheelers would work in lieu of the $160 Toytec spring perch?
According to the thread that was posted....
I believe it’s this one.....
https://wheelersoffroad.com/i-25489...-preload-spacer-kit.html?ref=category:1404758
So before I pull the trigger, is there ANY reason I should get the Toytec Spring perch in lieu of this part from Wheeler's? At a $120 savings between the two, the reason will have to be pretty damn good if one even exists.These don't go over the body of the shocks so he will say no, they replace the rubber stock isolator that goes between the top hat and the coilover springs. This will be my temporary solution until Dobinson releases our line of springs.
The product from Wheelers is SKU: DAY TA3273
Which is advertised in two product pages, one list the achieved height and the other list the replacement isolator actual size, both share the same SKU number
https://wheelersoffroad.com/i-25489...-preload-spacer-kit.html?ref=category:1404824
https://wheelersoffroad.com/i-25489759-3-4-poly-coil-isolator-pair.html?ref=category:1404824
Tacoma gen2 trd baja and pro 6112 guys have used this product for awhile. I recall something similar to this being sold in my gen1 Tacoma days
