Bilstein TRD Pro suspension kit on sale PTR13-35140
Care to give a fellow kdss owner some inout on where i should leave the clips? I will be running wheelers isolator up front and eibach pro lift rear springs. Not sure if i should install both on bottom or both on top or passenger side on top for kdss lean? I would prefer a minimal rake
Kdss guys please free to chime in!
Sent from my SM-G955U using Tapatalk
It was posted a while back. I believe for KDSS you leave both clips at the top position. For non-KDSS driver top passenger lower. Good luck!
Completed my install this morning, just need to get it aligned tomorrow (FYI, Firestone is doing $30 off a lifetime alignment until the 7th right now).
I did the install with KDSS so here are my lessons learned:
For the front, I put both clips in the top notch, and both sides are sitting at 37".
I ratcheted up my KDSS piston, in order to do the no spring compressor method. Re-attaching the KDSS took about 5 with two ratchet straps.
I used the jack nuts recommended by VmaxEngage (Post #230). I found them at Ace hardware for $0.99 a piece and used a 7/16" bit to enlarge the hole. I used a home made "friction wrench" and was able to screw them in pretty easy.
It took 5 minutes, or 5 guys? lol.
I was amazed too, the KDSS turned out to be a small footnote in the job.
The key is to ratchet strap it while all 4 wheels are on the ground. When you return the wheels to the ground the passanger bracket falls right in place. Drive side requires another ratchet strap to close the distance and screw right in.
Are these still on sale for a 2018 TRD Offroad 4Runner w/o KDSS? If so, does anyone have a link?
I want to make sure I'm ordering the right thing. Every keeps talking about how great of a deal it is, but the links only show about $23 off. Please help clear this up for me.
There is one for sale in the classifieds here. In the suspension and wheel section.
Here's an Ebay link as well: https://m.ebay.com/itm/GENUINE-TOYO...-Trail-Team-Lift-Suspension-Kit-/183080402808
Old Yesterday, 12:38 PM
#1 (permalink)
joeycduong [OP]
Junior Member
joeycduong is on a distinguished road
FS: TRD FJ Bilstein Suspension Kit, Works with 5th gen, $600 So-Cal
TRD Bilstein Suspension Kit for FJ Cruiser, will work with 5th gen 4runners, Part Number PTR13-35140
Comes with 2 Front springs, 2 front shocks, and 2 rear shocks
These shocks are Bilstein 6112 front and 5160 rear tuned by Toyota
Brand New, open box
$600
So-cal, pickup or driving distance preferred
PM if interested
Even though this kit is for the FJ cruiser, will fit the 5th Gen 4runner as discussed in this thread
http://www.toyota-4runner.org/5th-gen-t4rs/5th-g....3-35140-a.html
The website is misleading showing the $23 off and just shocks. It is the correct kit (Part no. PTR13-35140.) I received mine from them last week and its all there. Installing next weekend.
So this is just $23 off shocks?
Do your research. Its close to 65% off. SMH :rolleyes:
this is from the 1st post from the OP
Wanted to give everyone a heads up. PTR13-35140 trd Pro suspension kit is on sale (clearance) from toyota. This kit is listed for the FJ but I believe it fits 5th gen T4r as well. These are trd tuned Bilstein 6112’s with I believe ebach coils and Bilstein rear 5160’s resi. These retailed for $1650....now $573. I’ve seen a couple places listed at $540. Looks like a smoking deal!
Bought this kit for my new T4R 3 days off the lot. Install was straightforward. Used the KYB top hats link a few pages back. Don't have the exact measurements in front of me, but it was right an inch lift up front.
-265/70r17 Nitto Terra G2
-TRD Wheels
Installed the rears today
Installed the rears today since I have KDSS I purchased the clamp from 4wheel parts. Anyone else out there use this clamp? Did I install the Reservoir right?
Just pulled the trigger on these from Frank Motors on eBay. Even though I am local to Frank in San Diego, it would’ve been $570 to pick up. I ended up getting them for $530 shipped with the coupon code on eBay right now which is 15% off. The code is “PMAY4TH” and it ends tonight at 7:00 PM PST.
...now to see if a buddy can help with the install. Or if anyone has any recommended installers with KDSS in San Diego, let me know!
-TRD Wheels
What sliders are those?
-TRD Wheels
You have the exact same setup as I do, I like how yours turned out and I’m nervous about adding the front spacer and rear coils for a 2.25/1.5” lift now
peacefulpiranha
