wfo9
LOLNo trimming of fenders on a +2 kit. On a +3.5? Yes.
Maybe with 33s.
I'm fully expecting some issues with 34/35s. Bump stops will probably solve it for trail use, but if you really want to get out and take advantage of the full up travel.. (even with 33s) I think some cutting will be required.
It's really hard to know until you try it.
[MENTION=89562]bimrunner[/MENTION], there is a pretty easy method to check it with IFS as a starting point. Pull out the coil over and compress to the bump stops in the air and try all the different steering angles. Hard to know for sure until you get an alignment... + there will be additional bushing and tire defection in the real world.
I plan to stick to 34s for a while, but will at least go to a 315 next set.
