Blackstone Report
hearno
Senior Member
Here's my first oil analysis. Since I own a V6, I'm naturally concerned about the head gasket issue so I stressed the coolant in the oil issue. Here's what they said. Anyone have any input regarding the rest?
did they have anything to say about it?
why is the magnesium so high?
also, silicon is a bit high...generally that's dirt. what air filter are you using?
The Magnesium was the same on my V8.
I was looking at your thread comparing mine but you have the V8 so I threw mine up also.
OP: What brand and grade of oil?
Castrol Syntec 5w30
I see a problem.
You're looking at Jeep Wranglers for sale....
LMAO good eyes. I forgot that was down there. Good thing it wasn't pron.
^^^ I saw the same problem :wow2:
Negative! I'm looking for rubicon take offs. I have 2 new tires and I need 2 more.
[MENTION=84120]nevada[/MENTION] I did some searching and found that detergents can cause the magnesium levels to spike. I seafoamed the fuel and oil right before the last change. I'm sure that's a result of residual. As far as the filter, previous owner put in some sort of "high flow" in the stock air box. I have been planning on returning to a stock filter in the near future.
good to know.
I expect with an OE filter in there, the silicon levels will go down. that's a good thing.
Hmmmm, I use fuel additives from time to time...
