Blizz86's 2000 Limited Build
Picked up a husky cargo liner and another hood deflector for 20 today.
Nice pickup. Just bought weathertechs. I was looking at the Husky liners as well.
This is my first time over to your build thread. You've done well! Looks fantastic.
20121016_180433.jpg~original
What the crap? Carrying dead hookers back there?
Just a small update.
Painted my shrouds black and installed xbaLeds on the inside of the apollos.
some roadshots for those who are contemplating a retrofit
Pics dont do much justice, so heres an alley shot - that far wall is beyond 100 yds away
freeway onramp
And installed a sportrack roof basket w/ extension (comes about midway of the moonroof, and retains the moonroof tilt function)
Changed my fuel filter because i havent touched anything in a while other than oil changes.. i highly suggest a flare wrench..i didnt think i needed it because there was no rust but whoever istalled the fuel filter definitely over torqued the IN end. The flare was completely crushed.
I found that out when i tried to start the engine after installing the new one. Gas all over my garage floor.
I had to go to autozone and get a 5/16 fuel line repair kit (came with a SAE nut on the flared end and a compression coupler on the other, and a 14mm nut for fuel lines. Replaced the nut and cut off the old fuel line about 8 inches towards the tank from the filter and added the new line Good as new.. only issue is my check engine light has been on for the past week.. engine runs fine and im getting about 2 mpg better..
Do you have a code from the CE?
Hey there
Just wanted to get some info on your lift.
How has the truck held up since you lifted it?
Did you have any driveshaft problems or weird vibrations?
