Blown Motor! (Supercharged)
TRD04RUNNER said:
lol hey momo just because you 're the mod dont give you a reason to cut in line!:xnuts: :biggrin2:
:headslap: ...I had pm'd him right after his first post of this thread, so I wouldn't say I am cutting in line. I think he will get it fixed anyway, so none of us will have the option.:(
that's really too bad about TRD USA not fixing it under warranty...
but like I've said way above..... I'll for sure take your rear jdm tailights off you should you decide to not keep it.
:D
Please keep us posted as to what Toyota determines the problem was. It seems the issue was the trans sticking, not the supercharger.
Congrats on the SL55, did you look at/drive the V12? I hear they are about the same, from the standpoint of speed?, I don't know about handling how they compare?
I looked at the SL65, but the price tag was WAYYYY too high, ill wait a couple years, since its prob gonna be worth 50k less.
j0.
Update
Well Toyota agreeded to pull the motor yesterday, and on examination, I bent two RODs, 8 and i think it was 3 also..
Nice!
j0
Are they still not putting it through warranty. An approved part sold through toyota, should not void the warranty, even if it was put on hold. You could have bought the sc two years ago, and put it on yourself last week without ever being told it was on hold.
Also, have you called unichip?
TRD sayin they never recieved my Warranty Card. thats whats all this grief is about....
BUT, they are in the middle of a move... (supposedly) anf trying to locate it.
j0.
Well after signing a work order to proceed with the repair, since Toyota Canada doesn't know what to do. It seems that they have DENIED my warranty claim.
So this will be my last post about this, since my Lawyer is now working on it.
Toyota Canada claims:
Since the charger was put on Hold in 2004, and you have installed it in 2005, there was NO warranty, since TRD discontinued the producted due to problems.
I'm waiting on TRD USA, to see what they have to say about this mess..
I took out 2, 8 rods, and I supposedly did damage to my head also.
j0.
(one very UNHAPPY toyota Owner)
You learned a VERY expensive lesson on installing after-market parts and then try to collect under warranty.
Even if you bought the parts from a Toyota dealer after-market parts will void your original warranty.
Cliff s
j0.
Seems like they would have to prove you knew this. Plus if it is a problem they would need to recall all of the units and take them off all of the vehicles and buy them back from the owners. Sounds like a lawsuit you can win. Good luck.
First off
AFTERMARKET PARTS WILL NOT VOID YOUR WARRANTY! They have to cause the problem. Second off, the TRD unit is warranteed by Toyota, so it would not void it. I had a SC on my 2000 4r and it was covered by not only the Toyota drivetrain warranty, but also the extended warranty- I know, they made warranty repairs on it.
Second, TRD needs to recall these units if there is a problem, like Pitbull said. This is a case that they cannot win, since there is no official statement from toyota or trd that prohibits dealers from doing the install, regardless of the timing involved. If you had an independent garage do the install, they would have no way of knowing there was a recall or issue with the unit.
There seems to have been an issue with the tranny shifting out of 1st gear, which is not controlled by the supercharger or additional ecu, as that function is controlled by the factory ecu, which sends out the signal, so how toyota can claim the supercharger was at fault is beyond me, as its possible the engine would have thrown a rod regardless, if it wasn't shifting.
Good luck, and let us know the final outcome when you can.
You might wan to read page #11 of the Owners Warraty Information booklet.
It covers alteration and aftermarket parts.
Cliff s
Cliff s
Cliff I understand that TRD (Toyota) parts do not void your warranty. This is a TRD supercharger.
Page 11 states that un approved parts may void the warranty, and it will only void the part that was damaged, not the entire vehicle.
TRD parts are approved.
Swapping in a lift kit, for example may void any repairs to the ball joints, but won't affect warranty coverage on your water pump. The damage caused has to be related to the part installed.
Its called the Magnusson act- not sure about spelling.
Yes, but jOmama is up here in Canada. Not sure if there are less stringent laws for Toyota to find a loop-hole and screw him over.
It is Toyota that backs the warranty and not the customer, they also set the terms.
There is enough fine print in all warranties to void them if any modification has been made.
Toyota and only Toyota will decided if they will honor the warranty in any case.
Sure you can sue them, but the cost of the suit would be many times the price of the repair.
Cliff s
Cliff s
Toyota would have to pay all your expenses including the Lawyer. :) Plus it sets a precedent that Toyota does not want. They will pay after the letter from the Lawyer. Watch :D
Toyota will cover the warranty, and then toyota is reimbursed by trd- its what happened on my old supercharger when the seal in the 3.4 sc went.
davebas
